#1 Posted : 29 November 2015 03:24:37(UTC)
When someone was asking about Merkur I found that I did not have any decent pages on my layout web site showing the roadbed, so I added this page:
http://cabinlayout.mixmox.com/1/Merkur-ballast
thanks 4 users liked this useful post by DaleSchultz
#2 Posted : 29 November 2015 04:21:02(UTC)
Hello Dale,
Absolutely agree.
K-track and Merkur "roadbed" is a marriage made in modelleisenbahn heaven !!!
PJ
#3 Posted : 29 November 2015 05:08:25(UTC)
are you ever contemplating or considering adding servo motors to your turnouts ? I have had trouble with mine for a long time especially double turnouts whereas the lever moved back a bit and the tongue of the turnout wasn't completely against the rail, mind you I've used he underfloor option but since I'm using servo motors the position is permanent and can't move backwards.
#4 Posted : 29 November 2015 16:44:33(UTC)
the underfloor mechanism from Märklin are a total waste of time. Mount the regular switch motors upside down after drilling a hole in the base so that it can be switched manually from below. I also tie threads to the inside of the mechanism so that I can manually switch them from above. See http://modeltrain.serveh...sf/1/Switch_motor_thread
#5 Posted : 30 November 2015 06:45:01(UTC)
the underfloor mechanism from Märklin are a total waste of time. .........................
Hello Dale,
Yes, that was my experience in my previous layout with the underboard mechanics.
PJ
Offline michelvr
#6 Posted : 01 December 2015 16:41:10(UTC)
michelvr
Hello Dale,
Before I started my layout I was tryinig to find a supplier for the Merkur roadbed but was not successful.
I then decided to use Midwest Products HO Scale Cork Roadbed and the Noch Ballast.
I call this roadbed, LOL Me-work-for! LOL
Very labour intensive but the picture speaks for itself!Cool
On my next layout I will definitely obtain Merkur roadbed. Thank you for your post.
Michel
Offline Mark5
#7 Posted : 03 December 2015 18:54:33(UTC)
Mark5
Looks great from the that angle Michel,
How did you ballast around your turnouts?
The track sinks into the Merkur roadbed in a way the cork bed does not.
A photo of the impressions in the Merkur roadbed without the track might be useful here.
Especially the pieces for the turnouts.
PJ, looks like one of your turnouts uses the moveable frog.
Is that correct? Have you had issues with these turnouts?
- Mark
Originally Posted by: michelvr Go to Quoted Post
Hello Dale,
#8 Posted : 04 December 2015 11:29:27(UTC)
- Mark
Hello Mark,
Yes , that is correct they have movable frogs.
I trust you have gathered that I am quite a Merkur enthusiast. One great point is that the "roadbed" for all the points has no ballast granules near the moveable parts, as you can see from the last image above and the blank below :
Re the frogged turnouts, I have only 4 of these since I have only used them in situations where I wanted the minimum parallel K track distance of 57mm - all the rest are double-slip 57mm switches in these situations, or in other situations the classical distance switches/double switches of 64.6mm distance.
I have been using the 4 frogs for 17 years and have had no issues with the frogs (except one which turned into a Prince LOL )
PJ
Offline NewMB
#9 Posted : 04 December 2015 11:55:26(UTC)
NewMB
Not wanting to steal the thread, but as i am finished with laying my track using the Merkur bed, i have loads left over and would be quite happy to get rid of it if anyone interested.
thanks 1 user liked this useful post by NewMB
Offline michelvr
#10 Posted : 04 December 2015 20:43:21(UTC)
michelvr
Would love to drive over and pick it up but the Atlantic Ocean is in the way! LOL
Michel
#11 Posted : 04 December 2015 20:45:55(UTC)
Hello Dale,
Michel
I bought a roll of the NOCh when I started my second layout thinking I may use it. I then read that multiple folk found that after 10 years it fell apart, so I stayed with Merkur.
Offline NewMB
#12 Posted : 06 December 2015 23:34:25(UTC)
NewMB
Michel
Happy to post.....have a long list if interested.....
Merkur Roadbed (H0-scale)
by Harvey 15/12/2018 22:04:04(UTC)
ex-Noch Merkur Roadbed (Small scale)
by Nightowl4933 09/03/2010 15:03:32(UTC)
This page was generated in 0.561 seconds.
