Offline adelrs
#1 Posted : 28 November 2015 02:28:07(UTC)
adelrs
Can I change the default digital address (which is 1) of a Viessmann 4554 switch motor using a CS2? Currently the CS2 recognizes and properly controls the switch motor. But I can't figure out how to change the digital address from 1 to another value. I haven't had the CS2 long so I don't if my problem is not knowing the CS2 that well or if I doing the connect the blue/green wire, power on, connect the blue/red wire, configure address sequence BigGrin properly.
Any help with problem is appreciated.
Offline sjlauritsen
#2 Posted : 28 November 2015 07:38:07(UTC)
sjlauritsen
Put the CS2 into emergency stop, connect the green wire and release the emergency stop, then connect the other wire. Now click the switch button that you want to use for the turnout. That should do it. The turnout will take the address of the first button that sends a command.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
Offline adelrs
#3 Posted : 29 November 2015 14:51:45(UTC)
adelrs
Got it working, Thanks for the information
This page was generated in 0.341 seconds.
