Offline Thewolf
#1 Posted : 26 November 2015 12:45:50(UTC)
Thewolf
Hi everyoneBigGrin
I want to buy this signal. And this is the first time. I never see a signal with this accessory
But when I look at this photo
something worries me
Two of this signal will be placed above the hidden ways, thus at the level 1
The small case at the end of 3 wires, I need to remove it to make the wires pass in a 4 mm hole. Is it practicable ?
Thank you for you reply
Have a good day
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline Thewolf
#2 Posted : 26 November 2015 18:03:53(UTC)
Thewolf
Forget my question. I have the answer
Thank you
Thewolf
Offline ae66green
#3 Posted : 16 January 2018 04:12:27(UTC)
ae66green
I have exactly the same issue, could you please let me know how you took out the Small case?
Offline Thewolf
#4 Posted : 16 January 2018 04:39:06(UTC)
Thewolf
Hi ae66green
My 7439 are connected to 1 M84.(60841)
From M 84 three wires (light blue 1, dark blue 1 and 1 red) were cut off from 1 meter .....74391 placed on the layout were together connected with marklin sockets and additionnal wires..on the other border of 60841,the same thing for the red wire ( border B of the track)...For me, no problems for the small holes
Don't forget, 2 or 3 red wires for the 60841
If you want, I can make pictures for you
Thewolf
Offline ae66green
#5 Posted : 16 January 2018 14:36:45(UTC)
ae66green
Hi The wolf
I use the same things m84 and 74391. Do you mean you cut the wires and put the wires through the small hole and then re-connect the wires to the plug again with the Marklin socket? Do you mind showing me the picture/photo? I don't want to cut a big hole on my layout to let the big clip (plug) at the end of the 3 wires to go through.
Thanks.
Offline Thewolf
#6 Posted : 16 January 2018 14:51:56(UTC)
Thewolf
Hi ae66green
Don'be worry..This is the only way .
I shall post the picture as soon as possible
Thewolf
Offline Thewolf
#7 Posted : 16 January 2018 15:18:07(UTC)
Thewolf
The pictures here
You see M84 with a little hole
The lights are ok
you see green and red sockets
you see the red wire ...I don't need it....cut ...because all my laout ( locos, uncouplers, turnouts,et,,,) is controlled by Itrain
Hoping that it helps you
Thewolf
Offline Rwill
#8 Posted : 16 January 2018 15:55:40(UTC)
Rwill
You would not need to cut and join the red wire anyway as it comes out from the M84 tab and is open ended for joining to the isolated track section (if used) and does not join the signal mast.
Offline Thewolf
#9 Posted : 16 January 2018 16:04:50(UTC)
Thewolf
I know...all what I wanted to say is this wire is not neccessary for my layout..the 74391 is taken care by ItrainCool
Thewolf
Offline ae66green
#10 Posted : 16 January 2018 23:04:56(UTC)
ae66green
Hi Thewolf
Thank you so much for your photos. They are clear enough to me.
Thanks again.
This page was generated in 0.536 seconds.
