Offline anderspihl
#1 Posted : 13 November 2015 21:05:30(UTC)
anderspihl
Dear fellow railroaders
Today I did an experiment. I tried to bind a lok function (sound) to one of my functioning S88 conrolled routes. I modified a well-functioning route and added one lok function (sound) command. The result: The route continues to function correctly but the sound command is not working. Actually, the sound only works when the layout is powered on.
And here is the strange part: After succesfully deleting the sound command again from the route, the loko continues sound when powering up the layout. Blink
What the h.... did I do wrong? I consulted the manual, but it is of no use in this part. Confused
Once more I hope to hear from more skilled people out there.
Anders Pihl Knudsen
PS: My apologies if the topic is already covered in other threads.
Edited by user 14 November 2015 15:26:25(UTC)  | Reason: Problem solved thanks to Clapcott
Anders Pihl Knudsen
CS2 60213+MS1, 60052 60VA Trafo, K-tracks, Viessmann 5211 (K83)
#2 Posted : 13 November 2015 23:56:37(UTC)
This is most likely related to the timing between a function on and a function off command.
If you look at the command tree for your route, you should see both a function on and a function off indication.
For a momentry function
If the commands are too close together the "front end" processor will have completed the on and off before the "backend " cycles around to look for work - the conclusion = no net work to be done.
Conversely if your function is specifically on and off, you may have seen the two icons and deleted one. Result function stays on.
I would suggest first extending the time delay of the "off" function.
To edit this value,
- enter Memory setup mode,
- call up the route in question
- tap and hold the icon for the "Function Off"
After a couple of seconds you will get a popup dialogue where you may edit the time delay
Offline anderspihl
#3 Posted : 14 November 2015 11:41:40(UTC)
anderspihl
To edit this value,
Thanks Peter, I will try Again.
PS: Do you happen to know why the sound command "sticks" even though I deleted both the activation and stop command?
/Anders
Anders Pihl Knudsen
Offline anderspihl
#4 Posted : 14 November 2015 15:25:45(UTC)
anderspihl
To edit this value,
Yes, the timing did the trick. I wasn't aware of the press and hold feature on the CS2.
And the "sticky sound effect" disappeared after the CS2 was shutdown.
Thanks a lot Peter
Anders
Anders Pihl Knudsen
thanks 1 user liked this useful post by anderspihl
This page was generated in 0.351 seconds.
