Offline jonas_sthlm
#1 Posted : 10 October 2015 12:40:28(UTC)
jonas_sthlm
Has anyone get able to flash project files created with mDT3 application ?
mDT3 application is upload the file on the local USB stick attached on CS2 so that work fine ThumpUp
I notes that fds file extension named wrong like the old mDT tool so did try to corect that for .html but that dident work.
The files is saved like this under locally attached USB stick on CS2.
H:\cs2\update\fds\DT_mSD-Da-884-SJ.fds 2KB
H:\cs2\update\fds\DT_mSD-Da-884-SJ.htm 9KB (I try to rename this to .html but that doesn't help)
H:\cs2\update\snd\DT_mSD-Da-884-SJ.html 7KB
H:\cs2\update\snd\DT_mSD-Da-884-SJ.snd 2736KB
The snd file show up under Sound flash like DT_mSD-Da-884-SJ.html so it can be selected and transfer into decoder.
This page was generated in 0.192 seconds.
