Offline oranda
#1 Posted : 09 October 2015 22:38:31(UTC)
oranda
Apologies if this is a stupid question, but can I operate a mixed population of Märklin mfx and DCC equipment together on one layout?
I'm thinking of mainly DCC signals with mfx locomotives together.
Offline sjlauritsen
#2 Posted : 09 October 2015 22:46:09(UTC)
sjlauritsen
There are no stupid questions. :-)
Yes, you can run mfx and DCC together using the CS2.
Please be aware that you cannot run MM, mfx and DCC together - at least not with the CS2. Other control systems might give you other options.
With the CS2, your options are:
- mfx + DCC
- MM2 + DCC
- MM2 + mfx
If you do not have any MM2 locomotives, you are in good shape. Otherwise your MM2 locomotives will need a new decoder that supports either DCC or mfx, or both (Märklin, ESU M4).
Update: If you use Auto-mode instead of selecting any particular protocol, you can run MM2+DCC+mfx together on the CS2.
Edited by user 10 October 2015 08:03:33(UTC)  | Reason: Updated the answer with correct information. Striked out wrong part of the answer.
Søren from Denmark
Offline Hackcell
#3 Posted : 09 October 2015 22:52:47(UTC)
Hackcell
Costa Rica
Yes, you can run mfx and DCC together using the CS2. Please be aware that you cannot run MM, mfx and DCC together - at least not with the CS2. Other control systems might give you other options.
- mfx + DCC
- MM2 + DCC
- MM2 + mfx
Are you sure? If I'm not mistaken if you leave the CS2 protocol in auto, it will recognize the 3 protocols.
I'll test later today.
Danilo Jiménez
Costa Rica, pura vida!!
thanks 1 user liked this useful post by Hackcell
Offline 3rail4life
#4 Posted : 10 October 2015 01:10:44(UTC)
3rail4life
Yes, with all three protocols enabled this can be done with the MS2, CS2 and ECoS.ThumpUp
Gordon
#5 Posted : 10 October 2015 02:23:10(UTC)
That's my understanding.
The caveat to this is if a loco supports both mFX and DCC, the CS2 will always use mFX when the CS2 protocol setting is set to 'auto'. The same with mFX / MM.
Offline sjlauritsen
#6 Posted : 10 October 2015 07:50:05(UTC)
sjlauritsen
You're right. I completely forgot about the "auto" mode. In auto mode, the CS2 will of course recognize all 3 protocols. I was focused on an option called "mm2+dcc+mfx" so I completely overlooked the auto-option.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
Offline baggio
#7 Posted : 10 October 2015 08:03:11(UTC)
baggio
And if you use a Roco Multimaus, can you run any Trix locos or American manufacturer's locos? I think I can. Am I right?
What about Marklin, verboten?
Thanks.
Offline sjlauritsen
#8 Posted : 10 October 2015 08:10:34(UTC)
sjlauritsen
According to the manual, the Roco MultiMAUS supports DCC only. So you can run any DCC compatible locomotive, which includes those from Trix and presumeably every digitally fitted American locomotive. The MultiMAUS is NMRA compatible.
Almost all Märklin locomotives are MM or mfx. This will not work with the MultiMAUS. Only a few of the newer Märklin locomotives supports DCC; but I am still not sure whether or not this is a new trend or just a coincidence.
You can check the manual here: http://www.roco.cc/uploa...S/10810_multimaus_en.pdf
Søren from Denmark
#9 Posted : 10 October 2015 09:47:36(UTC)
That statement is correct for H0 Märklin, but there are many I gauge Märklin locos with DCC.
DCC was invented for Märklin because MM protocol initially could not be used with I gauge.
#10 Posted : 10 October 2015 10:04:26(UTC)
The Intellibox II can now (or at least in 2016 when the module is released) support mfx as well as DCC and MM - there will be a new module that you need to purchase, but with it the IBII can support mfx - see
https://www.marklin-user...goes-mfx--new-mfu-module
You would then be able to use any combination of protocol that you may require with the IBII.
Offline TouchCab
#11 Posted : 10 October 2015 10:55:30(UTC)
TouchCab
Not entirely correct.
DCC was developed by the NMRA based on a system that was developed by Lenz for Märklin.
http://www.dccwiki.com/DCC_History
Many gauge 1 locos use the MM protocol. Are you referring to something earlier than that? What was the restriction for gauge 1?
Jens
This account is no longer active
#12 Posted : 10 October 2015 11:19:00(UTC)
Old MM decoders don't work if red and brown are swapped. Gauge I without centre rail: turn the loco around and it won't work.
Offline oranda
#13 Posted : 10 October 2015 14:12:20(UTC)
oranda
Many thanks to everyone who responded to my request for information.
It certainly has given me an even greater reason to get a CS2 and run it in AUTO mode, and more reason to investigate the other protocols available and how to apply them.
Offline witzlerh
#14 Posted : 10 October 2015 15:21:30(UTC)
witzlerh
I use my CS2 for MM, mfx, mfx+, and DCC. There are no problems with running them.
One word of awareness ( caution if you get easily frustrated and throw things...Flapper )
When programming a new multi-protocol decoder, do set the CS2 to the protocol you want to program in and then the 2nd thing you should program, (after programming the decoder address ) is to limit the protocols the decoder will speak or recognize.
I once spent hours trying to program a multi protocol as MM and it would only respond to DCC.
If I am correct, when a command is sent from the "auto" CS2, it sends out DCC first, MM next and then MFX.
Now I temporarily set my CS2 to MM ( or the protocol I want my decoder to be), I would then have no problems programming the decoder. Once done programming, I would then set my CS2 back to "auto".
Voila!
Harald
CS2 DB & Canadian Era 3-6
#15 Posted : 10 October 2015 15:43:24(UTC)
Maybe I didn't get your point, but when a command is sent to a DCC loco it will be a DCC command - same for mfx and MM.
With protocol set to DCC only, no commands will be sent to MM or mfx locos. But MM commands will still be sent to MM turnouts.
Märklin decoders default to ignore their MM address when they detect DCC or mfx on the track and they ignore their DCC address when mfx is present on the track, unless those protocol with higher priority have been disabled in the decoder.
ESU decoders treat MM, DCC, and SX alike, but ignore all three when mfx is present on the track and not disabled in the decoder.
#16 Posted : 10 October 2015 16:26:29(UTC)
This is what you use with Märklin digital system:
CS2 and MS2 trains:MM,mfx,mfx+ and DCC
CS2 and MS2 turnout/signal:MM or DCC
This page was generated in 0.721 seconds.
