Offline Tiki734
#1 Posted : 15 September 2015 14:33:49(UTC)
Tiki734
I recently picked up a tired CEB800 and the previous owner had a shot at rewiring it. There are a few issues with it so if I start with the wire from the right brush. It should come from the motor windings but I can't see where it has broken off. Will I have to unwind some of the copper wire to try and find it. From the attached diagram it appears that they solder the wires together in the middle and then wind the magnet with the 3 wire exposed at the end. Two go to the reversing unit. Problem wire highlighted in green on attached sketch. Any help would be great.
Roger 3000 wiring.pdf (156kb) downloaded 35 time(s).
This page was generated in 0.305 seconds.
