Offline Repro
#1 Posted : 24 August 2015 10:47:02(UTC)
Repro
G'day all, hope someone can help me.
I can get my 76391 signal working on the test track.
But when I wire it to the layout it doesn't work.
It just shows a red signal and can't be switched.
Any ideas?
All the best.
#2 Posted : 24 August 2015 11:44:35(UTC)
Do you know the address of the signal?
Do you have the original box? There is a strip in there that is needed to set the digital address of the signal..
Offline Repro
#3 Posted : 24 August 2015 11:50:28(UTC)
Repro
yes, I have set the address and the signal works fine on the test track.
But when hooked up to the layout, it doesn't work.
#4 Posted : 24 August 2015 12:10:01(UTC)
What is the difference between the test track and the layout?
Are you using the same central unit to control both layouts?
As an aside - are these V2 signals or V1?
Offline Repro
#5 Posted : 24 August 2015 12:29:01(UTC)
Repro
V2
There are two outlets on the back of the central station.
One is for the layout and the other is for the test track.
The test track is used for programing trains and signals etc.
thanks 1 user liked this useful post by Repro
Offline MikeR
#6 Posted : 24 August 2015 21:28:20(UTC)
MikeR
I suggest you check that you have connected the red and brown wires correctly and that they are not reversed. If the wires are reversed the light will probably turn on but the signal may not respond to commands.
Member of ETE
Offline Repro
#7 Posted : 24 August 2015 22:32:13(UTC)
Repro
All wired up correctly.
Problem with 76391 signals. (H0-scale)
by gauravk84 12/06/2020 12:08:04(UTC)
Program 76391 Signal with MS2 (Digital)
by reindeerdad 03/04/2012 20:57:14(UTC)
Wiring 76391 signal with 72442 braking module (Digital)
by rcartwri 04/07/2011 13:22:54(UTC)
76391 signal - works btwn switches? (Digital)
by SBB 19/01/2011 17:46:37(UTC)
Programming 76391 Signals (Digital)
by charles Sharpe 03/12/2009 08:26:05(UTC)
Programming 76391 Signal with IB? (Digital)
by jkoellmer 22/01/2007 00:12:03(UTC)
Strange problem with 76391 signals ... (Digital)
Belarus gbraux 12/11/2005 21:37:29(UTC)
This page was generated in 0.521 seconds.
