Offline GalacticAndrew
#1 Posted : 03 August 2015 13:53:39(UTC)
GalacticAndrew
I have some DB cars (4027,4024,4022,4047) with scratched roofs. Is it practical to paint them (I don't have an airbrush or anything) or should I replace the roofs (and if so where can I get them?)?
Thanks.
thanks 1 user liked this useful post by GalacticAndrew
Offline Danlake
#2 Posted : 03 August 2015 14:00:17(UTC)
Danlake
Hi Andrew,
Even if you don't have a airbrush, you try and buy a spray can (used for DIY and auto's) with a similar color?
Spray from a distance and better to do more light coats than one heavy (build it up gradually).
Brgds - Lasse
Offline hennabm
#3 Posted : 03 August 2015 16:18:10(UTC)
hennabm
Hi Andrew
See here for info;
"Well, the first job was to take the roof back to bare metal. This was with approx 320 grade paper.
From there a coat of auto etch primer was put down.
When dry this was flatted using 1500 and then 2000 grade. This was done dry with using only light pressure.
The top coat is again another auto product, from Frosts.co.uk and is called clear zinc coating. This I find to be a very close match to the original, having compared it with my boxed 4015.
The doors were taken back to metal again but only done with zinc as clearance is tight. "
HTH
1957 - 1985 era
What's digital?
thanks 2 users liked this useful post by hennabm
Offline Markus Schild
#4 Posted : 03 August 2015 22:00:17(UTC)
Markus Schild
Hi Andrew,
in building centers in Germany spray cans labeled "alloy - effect - varnish" (original: "Aluminium-Effekt-Lack") are available. The colour is similar to the colour used on earlier 4022ff cars.
Markus
This page was generated in 0.345 seconds.
