Offline NS1200
#1 Posted : 01 August 2015 12:28:32(UTC)
NS1200
Dear All,
My Primex version of the 3048 series 01 Pacific refuses to run after static display.
The lamps are working,there is a buzzing sound,nothing moves.
I suspect that the drive gear is stuck due to waxing of lubricating oil.
I took off the metal upper part,no problem.
Two small screws can be seen,one on the brush shield and one at the back of the motor.
Can i open both?
What is the best way to clean the motor and gear wheels please?
I donot want to cut soldered cable connections.
Thanks in advance.
Paul.
Edited by user 04 August 2015 12:54:50(UTC)  | Reason: Not specified
Offline SteamNut
#2 Posted : 01 August 2015 14:12:19(UTC)
SteamNut
It can be taken apart by taking off the two screws on the side of the motor but remove the two brushes on the side first. Should not have to remove any wires. Lighter fluid will work as a cleaner. However when you mention the buzzing sound it may be the reversing unit is stuck. Try pushing on the unit to get it working. You may need a new spring (maybe it is missing). Good luck-Fred
thanks 2 users liked this useful post by SteamNut
Offline NS1200
#3 Posted : 01 August 2015 17:23:57(UTC)
NS1200
Thanks Fred,
I might take it to the nearest Marklin shop just to be sure.
The old lady deserves the best service available.
Paul.
Offline biedmatt
#4 Posted : 01 August 2015 21:05:46(UTC)
biedmatt
Hi Paul, Remove the brushes and then there are two screws on the brush plate. One at the top left and one at the bottom right.
Matt
Era 3
Offline analogmike
#5 Posted : 01 August 2015 22:58:59(UTC)
analogmike
can you rotate the drivers with your thumb after removing the brushes? occasionally i have seen them prevent the armature from moving, but if not you will have to remove the two screws and gently lift the brush plate to remove the armature. it is not necessary to cut or remove any wires. remember; only lift the brush plate enough to allow the armature to wiggle out (with tweesers). you cannot bully it. then you can clean the gears with a mild solvent and compressed air (50 psi should do) and watch your eyes. when you put it all back together go easy with the oil. overlubrication is not good either. mikey
Offline Ausipeet
#6 Posted : 01 August 2015 23:43:25(UTC)
Ausipeet
Buy a can of CC cleaner and spray the whole unit, this product is safe to use on Plastic and wiring and cleans of all the built up gunk. then either use compressed air to clean or let it dry natuarrly then lightly iol gears .
thanks 1 user liked this useful post by Ausipeet
Offline Danlake
#7 Posted : 02 August 2015 12:17:59(UTC)
Danlake
I have tried above during a few conversion project when everything is apart.
It does an excellent job of cleaning and will be sparkling clean. However on 3 occasions I have ended up with noisy, squeaky gears afterwards and in one case gears wobbling afterwards. Despite giving them adequate lubrication afterwards.
For electrical stuff and cleaning of solenoid so etc I would recommend it. For mechanical stuff like gears I would not. Instead use a mild cleaning solvent and then blow dry with compressed air.
By the way I believe Marklin use ultrasonic cleaning bath when they have to service old locos.
Brgds Lasse
Offline Sparrow
#8 Posted : 02 August 2015 20:41:42(UTC)
Sparrow
I use warm water and dishwashing soap for gears and mecanichal parts. But you'll need to remove all wiring and electric parts first.
Best regards.
Luis.
thanks 1 user liked this useful post by Sparrow
Offline analogmike
#9 Posted : 03 August 2015 02:02:25(UTC)
analogmike
Paul; never forget to clean out the armature segment gaps with a wooden square type tooth pic. as the brushes wear down the residue will accumulate in the electrical gaps. the residue is conductive and will "short out" the armature. it will refuse to move when energized. mikey
thanks 4 users liked this useful post by analogmike
UnknownOceanSpiders 0.0
This page was generated in 0.820 seconds.
