Offline Danlake
#1 Posted : 30 October 2012 10:23:38(UTC)
Danlake
My first weathering attempt of the Faller goods shed 120154.
Despite what some modellers say is not recommend, I tried using only cheap art acrylic paintBigGrin
The advantages I found areThumpUp
Much cheaper than buying the small 3$ tins...
You can easily mix your own colours.
It gives a texture to the plastic which you don’t get with Tamiya or similar products.
Very easy to blend colours to create concrete or weathered roofs etc.
But you do need to give the plastic a good wash and scrub before starting any painting!
DisadvantageThumbDown
For items requiring a smooth surface (like a steel pipe or small window frames etc.) I would not recommend it.
Anyway below is some photos. Appreciate any comments. Thanks!
The roof was made with a watery green colour. As a wet acrylic paint will not easily stick to the plastic it creates a flacking effect. Light shades of rust and soot was then applied later.
The pallets where made by scrap plastic parts. The bales on top are painted blue-tac!
Brgds - Lasse
Edited by user 21 February 2013 07:36:46(UTC)  | Reason: Not specified
thanks 14 users liked this useful post by Danlake
#2 Posted : 30 October 2012 10:25:41(UTC)
Weathered look great.ThumpUp
Offline hennabm
#3 Posted : 30 October 2012 12:26:56(UTC)
hennabm
Hi Lasse
The shed looks fantastic.ThumpUp It comes across well.
I too have that shed and have left it as it came from Faller. Mine is also from around 1974/6 period and is showing a few signs of ageSad
1957 - 1985 era
What's digital?
Offline Ian555
#4 Posted : 30 October 2012 14:11:20(UTC)
Ian555
Hi Lasse,
That's very nice work. ThumpUp
Ian.
Offline BrandonVA
#5 Posted : 30 October 2012 14:17:25(UTC)
BrandonVA
Lasse,
I have this same faller shed, but without the weathering. Thanks for the inspiration and the tip about using acrylic. Do you water your colours down to create a wash, dry brush or both?
-Brandon
Offline Danlake
#6 Posted : 30 October 2012 17:33:39(UTC)
Danlake
Thanks for comments.
Brandon; for the cladding/bricks I gave it a non-watered colour. The art acrylics can be quite strong in colours so I found it’s best to tone them down (mixing some white/beige colours in it). When dry I then applied a contrast wash and wipe the top surface with some towel papers.
For the roof I used mainly washes, same effects used for the concrete. Each wash needs to dry before applying the next one.
Brgds - Lasse
thanks 3 users liked this useful post by Danlake
#7 Posted : 30 October 2012 19:06:03(UTC)
Nice work anyway!
A tip...use an baseground colour to put on the plastic parts before you start to weathering building.
It makes in better condition to add dirty way.
And besides...to washing plastic parts???
I have never done this and it wont help either too.
Offline kbvrod
#8 Posted : 30 October 2012 20:35:42(UTC)
kbvrod
You have been a member since:: 23/08/2006(UTC)
Lasse,nice job!ThumpUp Some matte finish would be nice,...Smile
A couple of things:It may not be necessary to wash plastic in warm soapy water,I do this step.There was(in older kits) a release agent used to take the plastic out of the molds.This can cause a problem with paint.
Also dry brushing helps a lot!
Dr D
thanks 1 user liked this useful post by kbvrod
Offline kariosls37
#9 Posted : 30 October 2012 21:30:15(UTC)
kariosls37
A great bit of weathering DanlakeThumpUp
The only thing I wouls add is a light coloured wash to pick out the cement between the bricks, but otherwise it looks great.
I don't tend to wash my structures before painting, however, I do make sure any rolling stock I build is washed in warm soapy water before painting. The paint stays on so much better after washing which is important as my roling stock can get knocked around a bit. It is not just the manufacturing process that puts grease and oils on your models, but handling the model with your bare hands also puts oils from your skin onto the model that will cause paint to peel.
Rick
Offline Danlake
#10 Posted : 31 October 2012 04:41:05(UTC)
Danlake
Some good advice - thanks for comments guys!
Brgds - Lasse
Offline Smudge
#11 Posted : 11 December 2012 14:50:04(UTC)
Smudge
I like to build the flat walls, weather with a blackish wash and dry brush the highlight colours. Paint in the brick mortar by painting all the brick white/grey then quickly wipe the paint off the tops of the bricks with a damp rag leaving the mortar in place, this also helps to take away that horrible plastic look. Then glue all the walls and roof together and then a bit more weather to finish off
Smudge
Marklin Modellers of Sydney
thanks 1 user liked this useful post by Smudge
Offline petestra
#12 Posted : 11 December 2012 15:06:20(UTC)
Hi Lasse, the shed looks great. I really like the way the roof turned out. It looks like rust on
metal. PeterThumpUp Smile
Offline Danlake
#13 Posted : 12 December 2012 15:35:41(UTC)
Danlake
Hi Peter,
Brgds - Lasse
Offline glight1
#14 Posted : 12 December 2012 16:01:48(UTC)
glight1
Very nice effect on this model. I too have always used acrylic artists colors and like them a lot. In my experience, pre-washing in soapy water also helps.
A bit off subject...the photos that you have taken are great. What camera do you use and what is your technique?
Gary
Offline Danlake
#15 Posted : 12 December 2012 16:29:39(UTC)
Danlake
Hi Garry,
The camera is Canon EOS 60D (DSLR). I just used white A3 as backgrounds.
The camera is set at low aperture which creates a blurred background.
No flash - just normal backlight.
Brgds - Lasse
Offline Mark5
#16 Posted : 16 December 2012 08:06:50(UTC)
Mark5
Thanks for posting... wash and wipe works great for me too!
I do find that I am going for more exaggerated contrasting in mine... I think it makes it stand out more and compensates for scale.
Will have to post photos some day of my work ....
Carry on with the adventure...
Mark
#17 Posted : 16 December 2012 23:00:38(UTC)
Hi Lasse,
I have been looking for a shed of those proportions, thanks for posting the excellent pictures.
The weathering is superb. You don't have to worry about the colour of the mortar between the bricks in all structures, as it was often coloured deliberately the same as the bricks.
#18 Posted : 19 December 2012 21:39:31(UTC)
I have this shed, thank you for showing what can be done with it!
Mine is still all "plastic-pristine", so it can look a lot better... BigGrin
#19 Posted : 20 December 2012 19:29:38(UTC)
I have this shed too. I didn't weather mine, but I did paint it in matt enamels to get rid of the plastic shine. The weathering comes naturally after some time! BigGrin
This is the shed on the layout. In this photo all the paintwork is not yet finished, and it's still missing some details.
#20 Posted : 21 January 2013 21:18:05(UTC)
Offline NZMarklinist
#21 Posted : 22 January 2013 07:42:27(UTC)
NZMarklinist
You have been a member since:: 15/03/2011(UTC)
Nice work Lasse, ThumpUp
I have a few Faller kits to build for my new layout, and I do want to weather them to some degree, so some good hints, both from your self and others ThumpUp
Glen
Auckland NZ
Offline jørnet
#22 Posted : 15 February 2013 09:02:50(UTC)
jørnet
It looks really good.
I have started to always paint the plastic, even if it already has the correct color. I always use cheap acrylic paint. If you have problems making it stick, then ad just a drop of dish soap, this removes the surface tension and the paint distributes evenly.
For brick walls, I use some of these dry powders in water and again a drop of soap. The solution automatically distributes into the gaps between the bricks.
Jørgen
I just need space, money and time - That's all
thanks 1 user liked this useful post by jørnet
Offline Danlake
#23 Posted : 21 February 2013 07:34:10(UTC)
Danlake
Vollmer 5708 (water house). Again experimenting with cheap acrylic colours. I changed the house slightly and the water pipe is now on the front side instead of on the back side. I really liked how the roof turned out. I did a little bit of dry brush for highlights as well.
Brgds - Lasse
Edited by user 08 January 2016 05:21:50(UTC)  | Reason: Not specified
thanks 7 users liked this useful post by Danlake
Offline obxbill
#24 Posted : 22 February 2013 04:44:30(UTC)
obxbill
Very good! I agree, the roof looks great! Not overly done. Just the right amount of aging. ThumpUp
Bill
thanks 1 user liked this useful post by obxbill
Offline kbvrod
#25 Posted : 23 February 2013 00:33:30(UTC)
kbvrod
Hi Lasse,all,
The roof looks great!BRAVO!
However,....there was a reason the wasser krän was on the other side,....
Dr D
Offline Danlake
#26 Posted : 30 July 2015 11:04:47(UTC)
Danlake
A few more photos of kits being painted with cheap acrylic paint. Still my favorite way to paint/weathering of structures.
I normally paint everything before gluing together and then do a final touch up/weathering in the end. The hardest part is not to overdue the effect but trying to keep everything subtle.
Brgds - Lasse
Edited by user 08 January 2016 06:05:22(UTC)  | Reason: Not specified
thanks 12 users liked this useful post by Danlake
Offline Fishman
#27 Posted : 31 July 2015 01:54:53(UTC)
Fishman
Nice work anyway!
A spray undercoat is almost essential to give a good base to paint onto.
It is something that should be done with all models, plastic, white metal or resin, in order to get rid of any residual mould release oil. If you dont do it the paint will not adhere to the model and either becomes patchy and streaky or peels off when the model dries. Warm soapy (dishwashing liquid works best) water to wash, a toothbrush to scrub into the crevices and clean, running water to rinse.
Those buildings look really nice. When are you going to start highlighting on the figures?Flapper
thanks 1 user liked this useful post by Fishman
Offline GlennM
#28 Posted : 31 July 2015 13:02:02(UTC)
GlennM
Hi Lasse
I know how the shed feels LOL LOL LOL
Offline BrandonVA
#29 Posted : 16 September 2015 20:00:39(UTC)
BrandonVA
Glenn, all,
A little (lot) late to the party, but I agree....for most applications a matte finish works well, and I too favour using acrylic paints for weathering. They're easier to correct if you make a mistake. I think dry brushing is easier as well (or maybe just a lack of skill on my part). Washes are also possible if you water the paint down, but tend to require several coats whereas an oil-based paint will not when used as a wash. Cleaning the parts is a good idea as suggested.
Here are a few of mine:
thanks 17 users liked this useful post by BrandonVA
Offline Mark5
#30 Posted : 13 October 2015 20:46:20(UTC)
Mark5
Perhaps this should be a new post, but wanted to give this great post of yours a bump up.
Anyone use "pan pastels" or just try powdering dry pastels to dust on and weather?
Guessing the the "pan pastels" are just powdered dry pastel with a bit of binder...
... any quality binder would do anyway...including your drying undercoat.
Pax Lokana,
Mark
Offline Thewolf
#31 Posted : 13 October 2015 20:58:47(UTC)
Thewolf
Hi eryone BigGrin
For my layout and for all which concerns the decoration, the patina and the buildings, it is Madam Québec who has it the responsibility.
And I shall soon make a post with its works. She surprises me with the quality of her work a lot. Normal: she is a Quebecker of origin
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline Danlake
#32 Posted : 08 January 2016 06:01:50(UTC)
Danlake
A few more photos.
This time old classic Heljan building which have been produced for many years.
Brgds - Lasse
Offline Danlake
#33 Posted : 07 July 2016 08:10:56(UTC)
Danlake
I made a video tutorial of painting and weathering of my latest building for the layout, a Faller signal tower.
Purpose of video was to show how fast and easy it can be to do some basic weathering techniques.
Brgds Lasse
thanks 4 users liked this useful post by Danlake
Offline applor
#34 Posted : 08 July 2016 06:19:34(UTC)
applor
Thanks for sharing the video! Looks like a lot of work. I noticed you washed the plastic to begin with, is that necessary is it?
Offline DV
#35 Posted : 08 July 2016 08:43:47(UTC)
DV
Great video, very informative.ThumpUp ThumpUp ThumpUp
Also excellent sound track (for me anywayBigGrin BigGrin ). Who and what was the soundtrack??
Dusan V
Offline Danlake
#36 Posted : 08 July 2016 09:47:38(UTC)
Danlake
Thanks guys,
The soundtrack is Jack Savoretti (before the storm). His latest album is Written in scars which I can also highly recommend.
Regarding washing the plastic. Not always necessary, but does help getting rid of any oily containment from the plastic mouldings process, which can make it difficult for this sort of paint to adhere to.
On the other hand you can also use it as an advantage. If you want to have a flaking, scaling look you can make a wash and let it air dry. That's how I made the green roof in post no.1.
I guess work effort is relative! Sure I spend a few evenings on this project and could probably have gone faster with some simple air brushing. However even with airbrush you don't get the texture as you do with this type of acrylic paint.
And you only need to buy 5-10 tubes of different colours and you mix and tone you fancy.
Brgds Lasse
Offline applor
#37 Posted : 09 July 2016 01:31:23(UTC)
applor
Yeah I need to get my airbrush up and running.
Been trying to decide between bottled nitrogen or a compressor but I also need to buy a regulator and don't know what I should buy etc. so nothing much is happening lol.
I did buy a tube of cheap black acrylic from BigW though, so I can do some washes on my brick foundation bridge.
This page was generated in 1.899 seconds.
