Offline barrister2u
#1 Posted : 04 August 2012 14:00:29(UTC)
barrister2u
I started with Maerklin some years ago by buying Maxi sets, all of which I run with a 6446 transformer in AC.
I then decided to move deeper into Spur 1 and recently purchased the 55024 Berlin Commuter set.
It arrived, I put it on the tracks, turned on the transformer and --nothing.
I understand the passenger LEDS are run in digital only. So, I have no passenger lights.
I thought the set would run in AC.
Curiously, there are traction tires on one side of the driving wheels. How does the loco get power?
I need some help to understand these issues and to get it running.
Should I go digital and, if so, what is required?
Thanks, Mark
Offline Markus Schild
#2 Posted : 04 August 2012 16:32:13(UTC)
Markus Schild
Hi Mark,
The loco must be switched to "AC-mode" if you like to run it with your transformer. You must find a small switch as shown on the sketch below:
Code:
http://medienpdb.maerklin.de/product_files/1/pdf/55024_betrieb.pdf
Markus
Offline barrister2u
#3 Posted : 04 August 2012 20:19:20(UTC)
barrister2u
Hi Markus,
Thanks for the info. I found the switch. The train is now running. Thanks again, Mark
#4 Posted : 05 August 2012 00:40:36(UTC)
Now all we need is pictures of the set running..........! ThumpUp
BTW, Welcome to the forum Mark.
This page was generated in 0.498 seconds.
