Offline monty
#1 Posted : 30 June 2012 16:04:03(UTC)
monty
Hello
I have updated the MS2 to software n.1.81 .
I've seen that now is possible to load 40 locos on memory. Infact I have loaded a dozen of locos
BUT I'm not been able to recall any locos beyond the number ten position. They are in the list but I don't know how to recall the eleventh.... one.Confused
Thanks for the help.
#2 Posted : 30 June 2012 17:14:15(UTC)
Monty,
If you talk about the Mobile station No 1 MS1) you can only store 10 locos.
Offline monty
#3 Posted : 30 June 2012 18:02:43(UTC)
monty
no as I said is the MS 2 tht can memorize 40 locos
in the meantime I discovered the procedure, is a little bit complicated:
load more then 10 locos
go to the main panel of locos
go to the setup panel
free one slot (that of the locos you are in)
set a new loco
choose from the loco list the one you prefer...DONE!
#4 Posted : 30 June 2012 18:12:17(UTC)
IIRC you can select a new loco from the list without freeing a slot - just invoke the selection command from the menu for the occupied slot.
This page was generated in 0.409 seconds.
