Offline Drongo
#1 Posted : 22 May 2012 13:00:51(UTC)
Drongo
Hi Everyone,
I'm in the process of setting up my computer program so as to automate the layout. I'm using "Train Controller" from Railroad & Co. and being very ably assisted by a forum member. The main problem that I have at the moment, is that my layout consists of C track. For the s88 connections to work correctly, the tracks have to be isolated. This means that every piece of track has to be "cut" to isolate the 2 tracks - a big job when my layout consists of over 1,000 pieces of track. Confused Confused Confused Confused
My question is, do you think that Marklin have made a design error with C track - i.e. should they have produced the track like K track in that the rails are isolated? I realise that many users will never computerise their layouts, however, if Marklin is promoting C track as being the best standard, then they should produce the C track with isolated rails. Please let me know your opinions.
Greg
#2 Posted : 22 May 2012 13:30:16(UTC)
Hi Greg,
Can you explain why the rails need to be isolated from each other? Doesn't an s88 just need contact tracks? I know of many who have automated M Track layouts, as well as C Track.
If the method you are using for feedback requires the 2 rails to be isolated, perhaps you can use a different method?
Online river6109
#3 Posted : 22 May 2012 13:39:12(UTC)
Greg,
Whether or not Maerklin made a mistake is in the hands of the user.
I agree with you producing a C-track system wasn't so crash hot, with the early batch of tracks breaking into bits.
Official instructions for the C-track to isolate the track is cutting off the link between left and right connection strip.
regards.,
Offline Maxi
#4 Posted : 22 May 2012 13:44:08(UTC)
Maxi
I don't think that the C-Track should be isolated like the K-Track.
Sure it is a rather lengthy process of clipping the required tabs to create an isolated piece of track, but I think of it as another task in the building process.
I am not really a fan of just take everything out of the box, slap it together and then the building process is complete.
Contact tracks would be a method of allowing feedback abilities, but I am a firm believer that all sections of track need to be monitored so that if one or more rail cars decouple and are left behind that the system will not allow a locomotive to proceed until the intended path is clear. This assumes that what ever program you are using has been structured to monitor all connected feedback locations and make the proper decision if the complete path is clear before releasing a locomotive into the desired path from point A to point B.
#5 Posted : 22 May 2012 14:34:48(UTC)
For those who do not need circuit tracks all over the layout, insulated rails could lead to contract problems. Feeder tracks would require three wires.
You don't need insulated rails if you measure the track current or use contact tracks.
Any many people do not use automation or feedback at all.
IMHO it's good as it is: keep it simple for beginners, let the experts cut the connections when they need it.
I have insulated more than two dozens of track pieces and I must admit it's a boring job.
Offline witzlerh
#6 Posted : 22 May 2012 17:23:38(UTC)
witzlerh
At least you do not have to buy contact tracks. I do not mind as I am routinely changing my track layout. I like snaping the tab to isolate the rail. It is so simple to solder it back if you no longer want the contact track.
I do agree with Tom. Keep it simple for newcomers. With the right Xurcon cutter, it is a "snap" to cut it.
Harald
CS2 DB & Canadian Era 3-6
#7 Posted : 23 May 2012 01:10:43(UTC)
Greg, I am not sure you have asked the right question.
Using track rails for sensing (computer managed or analogue) is not usually (just) an issue between the rails of the same piece of track, but between the rails of adjacent pieces of track. For K-Track you would still have to do some work to remove the fishplates.
When you say ...
... are you meaning "the 2 rails"
... are you also not stating the work needed for the adjacent rails and extra power/sensor dropper wires
... and I am afraid you have me lost with "every piece of track"
Anyway .. No.. I do not think Marklin got it "wrong".
Do I think you are going overboard with reworking 1000 pieces of track? - Yes
P.S. Neither do I think ...
... It is but one option.
P.P.S. If you simply wanted isolated rails use Trix . you will have to reinstall the 3rd rail hardware Glare
#8 Posted : 23 May 2012 13:36:58(UTC)
Hi Everyone,
Greg
Hi Greg,
Take a look also at my article from some years ago now where I used the centre rail for detection - sure it only works with a pickup shoe but might give you some further inspiration...
Ross Stewart set me onto this tip when I was playing around with "C80Prox", a useful PC control program (script-based) written by Ross and Peter Worboys, this detection method works remarkably well.
Cheers from Melbourne
Edited by user 24 May 2012 05:53:19(UTC)  | Reason: Not specified
#9 Posted : 24 May 2012 07:03:13(UTC)
Greg,
I intend to use computer control.
I have marked out (Using masking tape) the beginning and end of the block, so the end of one block is the beginning of the next block etc. (this is a guide)
So in each Block at the beginning I have used a red insulator between the adjoining blocks, on hte FIRST piece of track I have cut the joining piece and attached the S88 Contact to the spade.
at the end of that piece of track I have put a red isolator. (on some blocks I may have made the isolation 2 track lengths). at the end of the block similar, decide how long the isolation is to be. Insert a red bit, cut a few connecting strips and then a red bit at the end of the block. and so on.
I have made my blocks approx 2 - 2.5 metres long.
Hope that helps.
Nev
This page was generated in 0.591 seconds.
