Offline fvri
#1 Posted : 26 March 2011 21:58:25(UTC)
fvri
LocCommander no longer works for updating the locs in the ECoS having PC protocol V.2 as some command syntax for setting the functions was changed.
In more detail funcsymbol is changed into funcdesc.
So I probably will release a new LocCommander version V1.0.0.28 to support this change in the ECoS PC protocol.
Frank
Edited by user 27 March 2011 10:48:21(UTC)  | Reason: Not specified
#2 Posted : 26 March 2011 22:52:07(UTC)
Thanks Frank,
Offline fvri
#3 Posted : 03 April 2011 21:11:06(UTC)
fvri
It seems not only some of the commands changed but also the function descriptions and their address/index. Strange the downwards compatibility between V0.1 and V0.2 is that bad! So some more work than expected to make LC compatible with V0.2.
Frank
#4 Posted : 03 April 2011 22:05:03(UTC)
I hope there will still be compatility left for us running the original CS1 unupdated to ESU "new standards"...
Thank you Frank for making the effort to update LocCommander! ThumpUp
#5 Posted : 03 April 2011 22:32:13(UTC)
Just run the current version!
This page was generated in 0.504 seconds.
