#1 Posted : 03 January 2011 12:54:55(UTC)
Central Station 60212 Reloaded V. 3.3.3 (a. k. a. CS1 reloaded or CS1R)
This is a review, this is not an attempt to write a manual.
I only use the CS1 to run my trains and cannot say anything about the Shuttle Train feature, S88 feedback and other areas.
I'm trying to write a neutral review in the first part, giving my personal reflections in the second part.
Here's a photo of the CS1 reloaded:
The display is monochrome with orange backlights. Display resolution is QVGA (320 x 240 pixels).
The photo is not very good, in reality the display has a better contrast.
Here's a "faked" screen shot (screen shots come out black on white, orange was added by me):
While I think the orange looks better, the remaining screen shots will be black on white:
This is an image at the true size of 320 x 240 (but because this is too small on current high-resolution computer displays, the other screenshots are resized to 200 %):
So back to the re-sized image: on the left I selected a DCC loco, on the right an mfx loco:
I prefer 28 speed steps for locos (for DCC locos I can choose between 14, 28, and 126 speed steps, for mfx between 28 and 126 speed steps).
Functions F0 through F7 can be selected either using the black keys beside the display or with the touch screen. F8 through F15 (F19 for DCC locos) can be activated via touch screen only.
I cleared the right controller and placed an mfx loco on the track (the gauge control in the upper left corner shows the progress of mfx registration):
A complete mfx registration takes about one minute because CS1/CS1R reads the whole set of mfx information during the registration; later all settings can be changed without requiring further reading of mfx settings.
Registration has finished and there is an "M4" button next to each controller that can be used to select the loco for that controller:
"M4" is the name ESU uses for mfx - same protocol, only different names.
After pressing the "M4" button for the right controller, the new mfx loco is shown there (using 126 speed steps and with the default loco symbol):
After switching to 28 speed steps and with a different loco image, it looks like this:
One feature I use a lot: the button at the bottom right in the middle (with the two locos and two arrows) allows to swap the locos between the two controller:
If there is only one loco running, I normally have it on the right controller. With two locos running: right controller, right track; left controller, left track.
Another nice feature: the Multi Mode: you see speed and direction of five locos and can use the function keys for the selected loco.
Very useful when shunting involves more than two locos.
Here I selected an empty slot:
The loco selection screen:
Here you see locos in a list, either sorted by name (button "ABC"), optionally with active (i. e. running) locos first (button "(A)") or sorted by address (button "123").
This screen provides many different filters: The buttons "1", "2", and "3" are your three favourite lists.
The loco buttons "Steam", "Diesel", and "Electric" filter locos by propulsion.
And the most selective filter is the address field on the right. I entered "85" and the CS1R only shows locos that have this address (mfx locos are selected by there MM address even though the address is not used for running; therefore it's no problem that the BR 85 (mfx) and the BR 185 both have address 85).
Here's the screen with the newly selected BR 185 on the left (using M14 with 14 speed steps because the new hobby decoders do not support more speed steps) and with a BR 120 on the right (it's Märklin #37538, a loco that came with a pre-installed ESU OEM decoder that supports 28 speed steps).
Here you see the Edit Loco screen for the BR 120.
The check boxes "Loco list 1" through "Loco list 3" are used for filtering in the loco selection; any combination can be set.
The available protocols (part 1 of 2):
The available protocols (part 2 of 2):
The loco image selection list (showing user-defined locos here):
An on-screen keyboard is used to edit the name of the loco:
Function keys can be modified here (symbols are selected from the lists):
Version 3.3.3 supports 20 functions for DCC locos and 16 functions for mfx locos.
I won't show all loco settings. Here's the screen where you specify acceleration and braking times (shown as seconds, not as register values) and speed:
The current monitor of the CS1R, showing current and track voltage.
The CS1 reloaded package includes an adjustable wide-range switching mode power supply (input 100 through 240 V AC, output 15 through 21 V DC stabilized, max. 5 A).
The keyboard screen with the four "digital" turnouts I have on my layout:
CS1R supports up to 2048 accessories, so I'm not near the limit yet ...
The "layout" I created for my four turnouts:
Here's how my turnouts look on the real layout (but I couldn't find a symmetric representation in the CS1R):
The General Settings of the CS1R:
Brightness and contrast of the display can be adjusted here and the limit of the booster can be set (it's 4 A for CS1R while the CS1 before the upgrade was limited to 2.8 A).
Part 1 of the languages list (German is missing, but is also on the list):
Part 2 of the languages list:
I only tested German and English.
The devices screen:
Connected Mobile Stations are also listed as devices here:
CS1R version 3.3.3 supports MS1s only (MS2 cannot be used with CS1 version 3.3.3).
The properties of the Mobile Station where you select the ten locos that will show on the Mobile Station:
Loco selection uses the same filters we already saw on the other screen, only the address filter is not available.
Now the locos are selected and the list was sorted using the up and down buttons:
This is how the screen looks after selecting a loco that is currently active on the Mobile Station:
I can see speed and active functions, but cannot change anything.
By the way: look at function key 5 on the left side:
The famous "squealing brakes off" function, sometimes only called "squealing brakes" has caused a lot irritation.
The symbol currently in use with CS1R shows pretty good what this function does (but you still have to activate the operating sounds to hear the brakes).
Back to setup:
With "Show numbers of existing functions" you get these small numbers next to each function symbol. Since some locos have 8 or more speaker symbols on the screen for their various sound functions, these numbers make it easier when you reference the loco manual.
And "Immediate stop of DCC locos at direction change" is another "cool" feature (as long as it is turned off): When I change the direction of a running DCC or mfx loco, the loco will stop using its braking delay, will then change direction and accelerate also with its delay.
I love this and use it very often: I wait till the loco is on a turnout, then I change its direction (I use long braking delays so the loco stops behind the turnout) and switch the turnout - and that's all.
MM locos do not support this; so MM locos still must be set to 0, then wait till it stops, then reverse the direction and accelerate again - with DCC and mfx loco a single click does it.
Because the delays are used, I can even change the speed before or after reversing - makes no difference if I do it quickly enough.
The setup screen showing my four turnouts with their German default names (normally my CS1R "speaks" German, but I used English for the review).
The Track Signals screen also has new features after the upgrade:
mfx (called "M4" here) can be turned off allowing mfx locos to be run with the MM protocol (if you want to do this - for whatever reason you may have (this allows testing locos that won't register automatically)).
"Create assymmetric track signal" (sic) reduces the flickering of lights for locos with 6080 or 6090 decoder (the problem is not the decoder, but the wiring of the lamps but it's a problem that all locos with 6080 or 6090 decoder and light bulbs share).
I never tried Selectrix. All my decoders that support Selectrix also support DCC so I use them with DCC.
The Network settings, here used without DHCP (while I was using a crossed cable between PC and CS1R):
After wiring CS1R to my DSL router, I could use DHCP:
The Shuttle Train screen:
I never tested this feature so I cannot comment it.
This is the setup screen used to program DCC decoders:
Works pretty good (but I can still do it faster using the real keys of my Intellibox than using the touch screen of the CS1R).
The screen where you program MM decoders (reading is not supported):
CS1R can search for the address of MM decoders (in the range 1 through 255; the motor is turned on to detect the loco):
Access Authorization:
(I never used this; probably good for trade fairs, shop displays and to prevent "damage" by children)
I never used this screen, either:
So far I never had to delete all locos.
And finally the Info screen:
The serial number has been faked ...
When connected to a PC or a network, a browser can be used to access the CS1R.
Here's the Start page with an Info screen:
CS1R allows to download objects lists (including the loco list) to be downloaded in Excel format:
You can upload and/or download your own loco images:
CS1R and ECoS 50000 only support small monochrome images, the new ECoS 50200 with colour display supports thumbnail photos.
Here's a part of my user-defined loco image list:
Firmware updates are uploaded through the web browser:
Usually there is one major upgrade per quarter.
Web browser is also used to create backups:
You probably guessed it: the web browser is also used to restore those backups:
You can click on "Display" to see the screen contents of the CS1R (embedded in the frame of an ECoS):
The contents are update periodically.
Function Mapping
The CS1 supported function mapping for mfx decoders with version 2.0.3 (maybe even earlier).
The function mapping screen is a large grid: at the top are the available functions (function outputs such as lights, ABD on/off, shunting mode, sounds for sound decoders).
The "+" buttons at the top row came with CS1R, but even with the "unreloaded" CS1 you could click there to change the intensity and mode of the lights.
For an mfx decoder it looks like this:
Light intensity can be set from 0 through 255, 153 is 60 %.
For an ESU DCC decoder it looks like this:
Biggest difference: light intensity can only be set in the range 0 through 15.
Additional Information
CS1 is no longer maintained by Märklin. Software version 2.0.4 is the latest release published by Märklin and still available for download.
CS1 us limited to 2.8 A booster output.
The CS1R package includes a crossed Ethernet cable (used for direct connections between CS1 and a PC) and a 90 VA power supply, a plastic pen for the touchpad and a CD-R created for the serial number of your CS1.
The upgrade software supports German only as far as I know. I pushed the CD-R in, pressed "Next" a couple of times, then I had to wait about 15 minutes and the upgrade was done.
Language can be a problem if errors occur during setup (but there are at least two fora in the world where you can ask for help).
CS1R is much faster than CS1 when it comes to switching screens. It brings many new features such a Multi Mode, DCC support, direction change with ABD for running locos, 28 speed steps for mfx locos, easy function mapping for ESU DCC decoders.
I never had batteries in my CS1, that's why you see the battery with the question mark on the screen shots. CS1 won't forget anything without batteries as long as it's always shut down properly. With fresh batteries, you can simply pull the plug and the CS1 will shut down automatically.
Currently a CS1R cannot be used as a slave with a CS2. A CS1 can be the slave of a CS2.
Both CS1 and CS1R can use a CS2 as slave connected to the sniffer port.
MS2s can be used if connected to the sniffer port, they cannot be connected to the Mobile Station ports of the CS1/CS1R.
Comparing CS1R and CS2
Both CS1R version 3.3.3 and CS2 version 1.5.0 support function mapping for mfx decoders.
CS1R also supports function mapping for ESU DCC decoders.
CS1R reduces the flickering of light bulbs in locos with 6080 or 6090 decoders.
CS1R allows mfx decoders to be used with 28 speed steps. mfx can be switched off.
CS1R supports Selectrix.
Personal Reflections
Some say that ECoS, CS1 reloaded, CS1 are for techies. Maybe I'm a techie, but I like the CS1R and I find the UI quite intuitive (with very few exceptions) and could use almost everything without using the manual.
I find the CS2 slightly less intuitive, but I also managed to use it with a little trial and error.
CS1R Features I Miss When Using a CS2
I like the loco selection screen of the CS1/CS1R much better (but I also use the Windows Explorer in Details mode only): all locos in a single row, sorted by name or by address. CS2 shows them in a grid, much like the Icons view of the Windows Explorer. Some may prefer that view, but I know the name of the loco I'm looking for and a sorted list in a single row is the fastest way to find it. The filtering helps a lot: when looking for a Diesel, there are only Diesel locos in the list, same for steam or electric. This makes scrolling much more easy.
When I change the direction of a driving mfx or DCC loco, it will slow down with its braking delay, then reverse the direction, and then accelerate with its delay (does not work for MM locos).
CS2 uses about 64 virtual speed steps for all locos: those with 14 physical speed steps and those with 126 physical speed steps. Some may prefer it that way, but I prefer the way CS1R works: if the loco runs with 14 speed steps, then it takes 14 clicks on the knob from standstill to full speed, with 126 speed steps it takes more clicks (but I never use more than 28 speed steps). This allows me to keep my eyes on the loco and still have good control over its speed by counting the clicks.
Just like with the CS2, speed can be selected by clicking on the dial - the number of speed steps makes no difference then.
CS2 Features I Miss When Using a CS1R
There is nothing that I really miss, but the CS2 has some advantages.
CS2 offers two ways to update the firmware: from an USB stick or live from the Internet (if connected e. g. to a DSL router). CS1 and CS1R allow updates only through the web browser UI.
USB can be used to connect mouse, PC keyboard, and USB sticks (for updates and/or backups).
I never tried a keyboard and prefer pen on the touch screen over mouse (but mouse can be used to rescue a mis-calibrated touch screen).
Clicking on the dial to select the loco speed works slightly better with CS2 than with CS1R.
Conclusions, Recommendations
CS1R and CS2 have much the same features. If you want photo-realistic loco images, go for CS2 or ECoS 50200. If loco names as text are enough for you, then CS1R or ECoS could be affordable alternatives.
If you want direct control over loco speed steps, try CS1/CS1R or any ECoS. If you prefer an UI that tries to hide the differences between decoders, go for the CS2.
CS2 shows locos for selection in a grid (6 columns, 5 rows). You can have either a "most recently used" list sorted by last usage (this is a default) or a full list sorted by name. If you have more than 30 locos, there will be more than one page. The list cannot be filtered, so if you have more than 30 locos you must find the right page, then locate the loco on that page.
A screen shot can be found here:
http://www.andreas-huste...bdd6ffff8130fffffff0.jpg
I find it easier to find the right loco with the CS1R - especially for large collections.
I prefer the CS1R over the CS2. They do basically the same things in similar ways, but I find CS1R more user-friendly and better suited to my needs and my taste - despite the low-res monochrome screen.
CS2 does some things a different way - and it also has it supporters.
But there are many areas I haven't explored yet: I don't use S88 feedback, I don't use the Shuttle Train feature, I don't use PC control.
Offline mmervine
#2 Posted : 03 January 2011 15:37:11(UTC)
mmervine
Tom-nice job! I just upgraded my ECoS to V3.3.3 a few days ago. I had not updated it since 3.0.1 and I was amazed at all of the improvements. Your review does a nice job of describing the features of the CS1 reloaded and ECoS!
#3 Posted : 04 January 2011 00:18:08(UTC)
Thanks Tom, that's a lot of work you've put into that post, much appreciated.
I want to upgrade my CS1 to Reloaded this year, and I also hope to try 'bridging' the CS1R and CS2 together with something like iTrains, which supports multiple controllers.
#4 Posted : 04 January 2011 00:46:21(UTC)
Thanks Tom, very much appreciated! ThumpUp
I am myself "inbetween controllers", either do I keep the CS1 in original format and get a CS2 so I can connect the CS1 without problems, or I upgrade to "reloaded" (actually had it on order but cancelled it sínce it took so long...)...
The perfect thing would be if you could control the CS/Ecos screen from the computer too in the web browser, and just not have it as a display since (to be honest) the original screen does not have the best clarity/visibility around today...
#5 Posted : 04 January 2011 01:15:26(UTC)
I found this interesting as I have not played with any of these controllers. (My Intellibox still does (almost) everything I need).
It does seem that these boxes are still loco controllers, or virtual 'analog' control panels. i.e. the user interface is a virtualization of analog controls - buttons that can be toggled on and odd etc. Including turnouts and accessories. There is also a track layout schematic, which is perhaps a step up from that level. I find that very sad in this modern day of HTML5 and modern portable computing. It is not a layout controller (and perhaps never meant to be one).
#6 Posted : 04 January 2011 07:31:00(UTC)
The CS2 takes this even further, with a visual representation of the old style Marklin Digital keyboards, complete with 16 virtual buttons!
Offline GSRR
#7 Posted : 02 February 2011 01:19:09(UTC)
GSRR
Tom,
Great review, I know it took a lot of time, thank you! I just purchased an ECoS 50000 1.3 and updated it to v3.3.1
I was looking at the ECoS color display manual page 34 concerning the Marklin Mobile Station. Aside from the display being color, are all of the details in this newer updated manual pertinent to the older monochrome model?
I understand you can use either model of the MS1, that you need a patch cable 610 479 to connect to the ECoS, and that the ECoS will update the software on the MS1.
Are there any tricks to using the MS1 or any problems?
Thomas
Offline Piggy
#8 Posted : 02 February 2011 18:02:13(UTC)
Piggy
Great review Tom. I realized how many new features have been added since my version 3.0.1, just downloaded ver.3.3.3 and plan to install it soon.
Thomas: I run the CS1 reloaded with two MS1's, no problems.
Kenneth
#9 Posted : 02 February 2011 21:05:28(UTC)
You can take Märklin #60124 or #610479 (two different numbers for the same item).
Some dealers may only have one of those - or may even have different prices.
Offline dnerasmus
#10 Posted : 06 March 2011 06:04:44(UTC)
dnerasmus
where do I download the 60212 v 3.3.3 reloaded firmware pse?
pse respond to daniel at dnerasmus dot com
#11 Posted : 06 March 2011 06:43:23(UTC)
Register on the ESU Forum.
Have to Quote your CS1 (Reloaded) Serial Number.
Will take a day or so to get approved then go to the ESu Website and go to Downloads.
NN
Offline Piggy
#12 Posted : 06 March 2011 11:26:01(UTC)
Piggy
I was yesterday told from guy in the local train shop, that updating directly from version 3.0.1 to 3.3.3 should be avoided since that will give problems. He said I should install version 3.2.1 before going to 3.3.3.
Kenneth
Offline Caralain
#13 Posted : 07 March 2011 00:05:51(UTC)
Caralain
Hey Tom:
Thank you for the review. Very well done. It must have taken you a lot of time making all these print screens. I have to agree with you. The CS1 reloaded is a great product more user-friendly than the CS2. Like you I haven't tried yet the module S88 but I am likely to give it a shot soon.
Pierre
thanks 1 user liked this useful post by Caralain
Offline nero328
#14 Posted : 07 December 2011 15:50:39(UTC)
nero328
This is an excellent review. I have a CS1 and am thinking about purchasing the ESU update and this is very helpful.
Question for those in the US who have purchased the ESU update from a foreign (German) dealer - does the package include a US-compatible electrical cord?
General question - will the update allow the CS to operate TRIX (DC) locomotives?
Thanks.
Nero328
#15 Posted : 07 December 2011 16:57:39(UTC)
I don't know, but the cable from the wall to the power supply ends in a standard two-pole plug, so maybe you have a suitable cable from another device (CD player, battery charger, ...).
Yes, if they have a decoder (you cannot operate analogue DC locos with the CS1).
Offline Caralain
#16 Posted : 07 December 2011 19:12:51(UTC)
Caralain
Hi Nero328:
Mine came with a US plug. I bought the ESU upgrade in the Netherlands, but the store is now closed. I am not sure if it is possible to order this product in the US because the manual wasn't translated in English. However it's not a problem because you can use the instructions for the Ecos 50000 or 50200.
As said by Tom, you can also just replace the cable netween the tranformer and the wall.
Pierre
Offline Brakeman
#17 Posted : 27 April 2015 19:32:53(UTC)
Brakeman
Hello Kenneth and others,
Running two MS1's with CS1 and CS1 Reloaded is not supported by the manufacturer according to the user manuals.
I'd like to know if this is just a recommendation because of the possible radio interference problems or a hidden functionality.
Please see below the quotes from Marklin CS update instructions (bda_CS_60212-update_DE-EN). I believe the German part is what they tried to say.
I have CSR 4.02 and thinking of getting EcoS Link for additional controllers.
Juha
2.2.5 Direkter Anschluss einer Mobile Station
Die Central Station bietet die Möglichkeit eine Mobile Station direkt
als zusätzliches Fahrpult anzuschließen. Weitere Mobile Station
können alternativ über das Systems-Netz mit dem Terminal 60125
angeschlossen werden. Die Anschlussbuchse für die Mobile Station
an der Rückseite der Central Station ist unter drei Alternativen frei
wählbar.
Werden an diese freien Buchsen weitere Mobile Station
angeschlossen, so können keine Schäden auftreten. In diesem Fall
ist jedoch die Einhaltung der EMV-Vorschriften nicht gesichert. Daher
ist dieser Anschluss nicht zulässig.
2.2.5 Direct Connections for a Mobile Station
The Central Station offers the option of having 1 Mobile Station connected
to it directly as an auxiliary locomotive controller. Additional
Mobile Stations can be connected to the Systems network by means
of the 60125 Terminal. The connection socket for the Mobile Station
on the rear of the Central Station can be selected from one of three
alternatives. If additional Mobile Stations are connected to these free
sockets, they will be free from damages.
In this situation, however,
adherence to your local regulations for preventing interference with
television and radio reception cannot be guaranteed. This type of
connection may therefore not be done.
#18 Posted : 27 April 2015 20:36:54(UTC)
The ESU manual for the Central Station 60212 "reloaded" allows three MS1s to be connected directly: "20.2. Märklin® Mobile Station An der Central Station können bis zu drei Märklin® mobile stations 60651 und 60652 direkt als zusätzliches Fahrpult angeschlossen werden. Weitere mobile stations können mit Hilfe des ECoSlink Terminals angebunden werden."
Offline blid
#19 Posted : 26 August 2015 16:13:37(UTC)
blid
I have a CS 60212 that has merely been used as a power source for the last number of years. I now want to give it away, but I would like to upgrade it to “reloaded” first. Where can I get the “reloaded” code?
I have emailed ESU and asked if it is still available from them but no answer yet. I don’t need the power supply and stylus in their former package.
blid
Offline sjlauritsen
#20 Posted : 26 August 2015 18:27:39(UTC)
sjlauritsen
I am pretty sure you can't. It is not offered anymore.
Søren from Denmark
Offline blid
#21 Posted : 27 August 2015 18:25:32(UTC)
blid
Unfortunately you were right Soren. I know it was listed as discontinued but I thought the code might be available somehow. Here is the reply from ESU:
Dear Sirs,
thank you for your email.
The Reloaded package is since 2013 out of stock. We can't send you any codes because you need a special produced CD for the serial number of you CS1.
We hope we could help you.
Offline amassac
#22 Posted : 21 November 2015 13:20:00(UTC)
amassac
Thank you for this very useful information.
I am actually an owner of a CS1 with the update done by Marklin, so it would be eligible for this further upgrade by ESU. Do you know if it is still possible to execute the upgrade?
In fact I was considering to buy the CS2 (60215) for Christmas, but the price is very high and I believe that with the upgrade you described I would get all the features I am looking for at a much lower cost.
The challenge is that I am afraid they do not sell the ESU 59990 kit anymore and furthermore, if I was getting it, the CDROM would need to be tailored on my CS1 serial number. Furthermore would I also need to add all the updates since version 3.0.0 up to 3.3.3 in sequence?
Any suggestion you may have would be greatly appreciated.
Sincerely
Alberto
Alberto
#23 Posted : 21 November 2015 13:46:49(UTC)
Hi, Alberto!
Yep - see post #21 just above your post.
You can buy a CS1 that was already "reloaded" (and keep your CS1 as spare parts donour) or an ECoS (in fact a CS1 reloaded with different speed knobs and RailCom+) or an ECoS II (with high-res colour display). Or a CS2.
Offline amassac
#24 Posted : 22 November 2015 18:38:30(UTC)
amassac
Thanks Tom
Aberto
Alberto
#25 Posted : 22 November 2015 21:14:45(UTC)
I think it was December 2012 when ESU announced that the CS1 Reloaded upgrade kit would no longer be available.
I did not find out about that until June 2013 by which time it was too late to upgrade my CS1, at least from a European source. I was however able to order the upgrade through a North American ESU dealer, as ESU in the United States were still able to provide the upgrade.
I don't know whether you still can, but you would be best to try to see if you can still order the CS1R kit via a US dealer. Either that or send an email directly to Matt at ESU USA.
#26 Posted : 23 November 2015 04:31:09(UTC)
Matt's email address is Matthew.Herman at esu.eu (substitute @ for 'at')
Offline Tom Jessop
#27 Posted : 23 November 2015 06:31:36(UTC)
Tom Jessop
Curious as to how many on here have & use a CS1 reload or original & would be interested in buying the upgrades to bring them up to present specs . I have the reloaded version but didn't worry about the ESU software upgrade & now wish I did purchase the changed software . In my case I was so impressed with what had changed virtually overnight in the MRR world I considered that "M" would not change directions so quickly to the CS2 but that's another story .
Matt Herman seems to be able to convince ESU to change & upgrade various Loc sound modules etc but I don't think they will come to the party with regards to the CS1. YES I will put my hand up for a upgrade if it happens again .
Cheers Tom in Oz .
#28 Posted : 23 November 2015 08:08:56(UTC)
"Reloaded" is the term coined by ESU. You probably have an "updated" CS.
Märklin initially shipped the CS1 with version 1.x software. Those had to be sent back for an "update" to version 2.0.3 (also receiving a hardware upgrade).
With "reloaded" you get a power supply, a stylus, and a CD-R with the version 3.x software. All later software versions are available free of charge.
Later CS1 shipped with version 2.0.3 and upgraded hardware right from the start.
Those who have a "reloaded" CS can install the latest ESU software from the site. Those who have an "updated" CS1 with version 2.0.3 can get version 2.0.4 from the Märklin site and could also install the "reloaded" package if it was still available.
Version 1.x: initial version.
Version 2.x: updated version.
Version 3.x or higher: "reloaded".
Offline Tom Jessop
#29 Posted : 23 November 2015 12:22:43(UTC)
Tom Jessop
Thanks Tom , Just had a look & found that I have V 2.0.3 . I know I down loaded 2.0.4 but was not able to install as I did not have a Modem installed for wireless working . I had been told that to install without doing the modem version was almost impossible , so I put the upgrade on the back burner & promptly forgot about it until now after reading the full posting of yours from 2011 . Still have my hand up if their is any interest from ESU for the full upgrade although I would really only need the CD for the software change . The new power supply would not be required as I don't plan to use that many engines at the same time .
Cheers Tom in Oz
#30 Posted : 23 November 2015 20:28:39(UTC)
To upload the update you need a cable connection between CS and PC - with or without switch/hub/router in between.
This page was generated in 2.008 seconds.
