Originally Posted by: Farkenoath
would any one here PLEASE have any Marklin Catalogs they would be willing to part with Please, would like to learn the trains and numbers and was informed that using the catalogs is a great place to start.
Thank you
Peter,
Why not start here -
http://www.lctm.info/Biblioteca/Catalogos/Marklin/index.phpThere are a large number available for download, and while I admit that reading online is not the same as browsing one in your favourite armchair, if you've got a laptop it's pretty darn close.
And you never wear them out.
If you want to cut down your work and download times, I'd suggest you pick a start date that you know your items probably fall into, and download for each 5 years.
ie start with say 1970, get '75, '80, '85 and so on. There are only a few items that did not last a full five years and it will give you a good starting point.
10 catalogues from 1955 to 2000 would cover off a lot of product, the one-time issues didn't really kick in until the 80's so prior to 1980 the range is relatively stable.
Once you've done this, anything you still can't identify you can either post a picture here, or just broaden your downloads to fill in the gaps.
Personally, I'd grab as much as you can off that site while you can and build up your library of e-catalogues while you obtain printed copies at your leisure.
You can often find them on Ebay but if you prefer to put your money into trains rather than literature, do the download.
N.Z
