Ausipeet Offline
#1 Posted : 15 June 2012 02:00:51(UTC)
Farkenoath
Total Noob here so please bear with me.
I am starting out in this venture and am wondering if it is possible to use a compressor, i have in my shed that powers my air tools drills, nil guns and such, if it would be possible to buy adaptors for an airbrush system, and if yes what sort of pressure to set the compressor on for the airbrush. when i run my nailguns etc i have the presure set to 60-90 PSI any higher and id blow the nails thru the roof. any help will begreatly appreciated
Peter From South AUstralia
kariosls37 Offline
#2 Posted : 15 June 2012 08:00:05(UTC)
kariosls37
A DIY compressor is all I use for airbrushing. No need to throw money at a fancy quiet modelling compressor when a simple shop compressor works just as well.
I use around 30 PSI, but I just work by what feels right, not by a specific pressure. Once you have done a little airbrushing you will develop a feel for it.
For adaptor pieces for the compressor connection, you could try a hardware store, or maybe the place you got your airbrush from.
Rick
 1 user thanked kariosls37 for this useful post.
kbvrod Offline
#3 Posted : 15 June 2012 15:39:56(UTC)
kbvrod
Hi Peter,all,
First,welcome to the forum!
>I am starting out in this venture and am wondering if it is possible to use a compressor, i have in my shed that powers my air tools drills, nil guns and such, if it would be possible to buy adaptors for an airbrush system, and if yes what sort of pressure to set the compressor on for the airbrush. when i run my nailguns etc i have the presure set to 60-90 PSI any higher and id blow the nails thru the roof. any help will begreatly appreciated<
The compressor you have,does it have a regulator?Tank?
As Rick said,30psi is about the upper limit on what you should use when airbrushing.
Dr D
Ausipeet Offline
#4 Posted : 15 June 2012 22:53:53(UTC)
Farkenoath
thanks guys this helps lots,
Dr D yes it has a tank and a regulator it is a full function complete unit bought from my local hardware store.
 1 user thanked Ausipeet for this useful post.
kbvrod Offline
#5 Posted : 15 June 2012 23:06:42(UTC)
kbvrod
Hi Rick,all,
>Dr D yes it has a tank and a regulator it is a full function complete unit bought from my local hardware store.<
Good! As Rick said getting fitting from your compressor to your airbrush might take some doing yet it can be done.
Now ask more questions!BigGrin
Dr D
agvera Offline
#6 Posted : 16 June 2012 13:01:36(UTC)
agvera
Argentina
I use a Sparmax DH-150 airbrush (double action) which is fitted with 0.4 mm orifice and 22 cc suction glass bottle. Manufacturer recomends to use air pressure between 15 and 45 p.s.i.
For air supply I bought a diaphragm compressor, which delivers maximum 35 p.s.i. 30 liter/min with an 1/4 HP motor which is enough for the service but has no room for more demand.
For fine art, an airbrush fitted with a thinner orifice will be better suited and for automotive, tanning or coarser applications a wider one will be better, by the way I use a simple action airbrush, with same air supply for large surfaces like painting landscape.
Alberto
Alberto
era II + III + IV
Mark5 Offline
#7 Posted : 21 June 2012 03:25:06(UTC)
Mark5
I am sure there have been threads on this before, but I would like to know if there is simpler way to do it, if working inside the home and not in a shop.
I have only used an airbrush in a printmaking lab before, and never for hobby work or anything that requires finesse.
The thing is I don't want to spend money and something that will take up shelf-space 95% of the year.
- Mark
Era III with DB, DR and FS from 1955 to 1964 (1), then later from 1965 to 1976 (2).
Writing a story for a film using model trains for two brothers working, one for DB, the other for DR.
Layouts in process: Dual set: Digital with a 6021 control unit, option to run in analog. Fan of signals, catenary, dense yard layouts.
Zoom of avatar image: http://en.wikipedia.org/...,_Montreal,_QC,_1893.jpg
kariosls37 Offline
#8 Posted : 21 June 2012 11:00:35(UTC)
kariosls37
Airbrushing is a pretty simple way of giving something a nice coat of paint. Spray cans are a bit simpler, but the quality of the paintwork goes down too.
You don't need to have any hi-tech equipment for airbrushing. I do my painting with a $110 airbrush, in what used to be a kitchen cabinet with a bathroom extraction fan that came from a renovation. The compressor is a simple hardware store one and when it isn't used for airbrushing, it can fill up car tyres too. When I airbrush, I take the desk lamp on my workbench and set it up inside the airbrush booth. My airbrush stand is two bits of plywood I chopped up and screwed to the frame on which the spray booth stands.
I could have spent a fortune on a modelling compressor, a professional airbrush cabinet, an airbrush stand and other mod cons that would be nice but you don't need. The only thing on my setup that actually cost something was the airbrush itself. The rest I already had or I came across for free and used to improve the booth.
I've seen it a couple of times where there are people saying you need this, you need that, without it you cannot get a good finish. It's rubbish. Yes, a spray booth is nice to have, but it's not essential. I have several models that were airbrushed on a workmate, with the only effective lighting being the sun shining through the window. No airbrush stand, no spray booth or anything else. Placed besides any recent model and there is little noticeable diffrence.
All you need to get started is an airbrush, a compressor you can hook up to it and a cardboard box to paint in. The rest is optional.
My best advice is just to buy an airbrush, hook it up to a compressor, put some paint in it and mess around for an afternoon. That's what I did, and I can tell you, you will quickly pick it up.
Good luck,
Rick
This page was generated in 0.387 seconds.
