Joined: 27/01/2012(UTC) Posts: 216 Location: united kingdom
Hi Guys. Does anyone know which control switches i need for a 451 G crane (early version ) ?
Neil.
All Metal Marklin Fan . |
Joined: 07/03/2006(UTC) Posts: 539 Location: Gold Coast, Australia.
Neil, is this what you are looking for: http://www.ebay.com/itm/...-Crane-HTF-/120897658420 ? This will also work: Märklin Control Box 97279 in newer grey box. Edited by user 28 April 2012 09:34:33(UTC)
| Reason: Not specified |
D.A.Banks |
Joined: 17/09/2006(UTC) Posts: 12,203 Location: New Zealand
Eckert Engineering on US ebay have the newer (white) control boxes.
D.A.Banks |
Joined: 14/01/2006(UTC) Posts: 748 Location: Wurttemberg
Hi Neil, The early version came with a pair of switches like these (one of each). But they had special stickers and were numbered 474/51 and 475/51. But there is no technical difference.  Regards Markus
 1 user thanked Markus Schild for this useful post.
Hi Markus. Yes they look like the ones, all metal construction types. Will get some on ebay DE site, none here in UK !! Thanks Neil. |
Does anyone know if the mechanisms and gearboxes on the early 451 G cranes are the same as the later 70** series ?
Can the drive parts on later versions be swapped over and used for donor parts on early versions if needed ?.
They are well engineered inside.
Neil.
Hi Neil,
Yes, the drive parts of the 7072 would fit mechanical also in the early version. But in detail a 1950s part every-time looks a little bit different from the later ones. Due to historic reasons I would avoid to mix up new parts in an old crane. It is always cheaper to buy a model in good working condition than restoring one.
Markus
Originally Posted by: DaveB  Yes, that's them!
Joined: 23/08/2004(UTC) Posts: 717 Location: Bury St. Edmunds, Suffolk
I gather you can use the 7072 control boxes as well,which would be a lot cheaper,perhaps someone could explain how this is done? |
Geoff (UK)
marklin HO from the 50's and 60's |
Originally Posted by: drstapes  I gather you can use the 7072 control boxes as well,which would be a lot cheaper,perhaps someone could explain how this is done? Hi Geoff, Yes, this can be done, but you need an additional control - box 7210. The functions "up/down" and "rotate" must be connected to the 7072, the magnet and the light (these are two functions at early cranes) to the 7210. Regards Markus
Marcus, Thanks for your reply, You really have the answer to everything!
Geoff (UK)
Thanks guy's for all your interesting answers on this post !
Neil.
Hello Neil, for the cran 451 G you need two control panels, panel 474/51 for "turn left", "turn rigt", "up" and "down" and panel 475/51 for light und magnetic funtions. Regards Wolf
Joined: 01/03/2008(UTC) Posts: 1,270 Location: France
Originally Posted by: 20-VOLT-AC  Thanks guy's for all your interesting answers on this post !
Neil.
Neil I have an extra control for that crane, but later (blue) version . It's yours, just send me an MP with your coordinates Cheers Jacques |
Jacques Vuye aka Dr.Eisenbahn Once a vandal, learning to be better and had great success! |
