YetAnotherForum
Welcome Guest Active Topics | Log In | Register
Tag as favorite
Beginning and the end of LFCM and SFCM motors...
digitaltrainshort Offline
#1 Posted : 10 June 2010 14:13:31
Hello to all!
Not so long ago, I have stayed without two of my models due to the completely destroyed LFCM and SFCM rotors on my Marklin models E41 and E94(194) German "Crocodile"...
Until this happened, I thought that it is impossible to loose the model because of rotor malfunction, but, I was wrong...
Before I say anything in front, I want you to know that I am using Marklin control unit 6021 and my models with LFCM and SFCM motors are all equiped with Marklin c80 decoders.
I always use my models as the protoypical ones and their maximum speeds depends on the speed of the prototype. When I had analog system, I had no problems with any of my Marklin models, but, after I converted them to digital system, rotors on two of my models are destroyed completely. Such severe damages on the rotor's collector, I have not seen in my entire life on any other rotor of any kind!
Copper sectors of the collector are completely destroyed and there are a big holes at the end of copper sectors in a shape of elipse. Copper is deformed and vanished on the places where the collector sectors are isolated. Deformation of the copper sectors are incredible and never seen before!
There is no repair for such damigies at all, unfortunately...
All my models was fully operational until the conversion and after 11 years (only!) of usage, catastrophic malfunction ocured.
The symptoms are:
- Model can not reach its prototypical speed in exact scale 1:87
- Model significally slows down
- Motor overheating
- Abnormal consumption of brushes
and final stage
- Model can not start running by itself but only if you push it by a hand. After a few circles, model comes to a dead stop.
When you open the motor, you could see catastrophic damages of the rotor's collector. That is the point of no return.
All my Marklin models are professionally maintained and such damages just can not be seen during usual maintainings. Brushes was changed correctly, motor(s) was thoroghly cleaned, lubricating was properly done.
Nothing shows that such thing can happen. But, it is obvious that the digital impuls voltage which can be measured in kiloherz or kHz, is not the same as the 50-60 Hz in analogue mode.
Therefore, there is quiet reasonable doubt that LFCM and SFCM motors (rotors) can not stand such freqency for longer period of time! There is also doubt that Marklin as manufacturer, knew about this very well but did not suggest anything to their, faithful customers and just let it happen and they, forced the customers to buy their new 5* sets and decoders which are, at least, abnormaly expensive! I can add that the price Marklin asks for conversion sets is simply out of mind as there are other manufacturers on the market who are offered decoders under much lower prices and most of all, acceptable prices.
Some of us do not see this as a problem and that is quiet undrestandable, but some of us might have serious problems with their models and effort to keep them alive.
This all depends on the free will and how each of us is using his/hers models. If you spend couple of minutes with your models per month or per several months, then every model that you buy, no matter who made it, will last forever! If you have a layout and spend couple of hours per week with it or in two weeks per month, then you should have this on your mind all the time! Models that you are running will not run for longer period of time or at least, they will not last as you expected for sure and then, you will be forced to change the rotor (if you are lucky enuogh to find that spare part at all), or to buy one of the awfully expensive Marklin coversion sets for that purpose.
Certainly, no rotor(s) on this Planet are made to last forever!
The choice is all up to you!
Here, I want to use this opportunity to ask anybody here on this forum, if they have unwanted LFCM and/or SFCM rotors that are not needed anymore and if they are in acceptable good condition, please, contact me directly on my e-mail:
Webmaster: Email removed, use the email button
I must add here that, almost, half of my collection is now in question because of the same failiure.
If someone can help me, please, contact me directly!
Thank you all on your attention and time!
With best regards,
Zarko Kristic
Computer Graphic Designer
P.S. I am sorry, but I was unable to attach the picture of the damaged rotor to this message!
Edit by Webmaster - here's one picture of the actual damaged rotor.
dntower85 Offline
#2 Posted : 10 June 2010 18:34:36
That sounds like the varnish on the copper wires on the rotor might of melted first causing a short in a pole on the rotor, that causes a weak field which then requires more power. Causing more heat which causes more melting.
It is possible that after running for 11 years that the wire on the magnetic field coils were near the point of shorting. even if the locos weren't run that much the varnish could of just broken down over time.
I have had good luck using original 3 pole rotors used with ESU permanent magnet and a lok-pilot decoder. Although not as smooth as a 5 pole they run very well. so you should be able to find some 3 pole rotors for relatively cheep on the used market.
And if you want it to run fast the lok-pilot CV's are factory set for a 5 pole motor, so if you leave that setting in with the 3 pole rotor, the decoder thinks it is running at 3/5 speed so the thing will fly around the track. Woot
Even with 5 pole motors I still have to take them apart and clean then at the first sign of slowing down. just the other day I tore down my V210 after it lost speed.
Sorry Zarko that you have had problems.
DT
Webmaster Offline
#3 Posted : 10 June 2010 20:45:06
To me, it looks like there are 2 distinct marks of erosion/deteriation of the copper plate at the location of the brushes of an xFCM motor.
A moving rotor should not have such distinctive marks - is it a longterm storage problem?
hemau Offline
#4 Posted : 11 June 2010 21:38:21
Well I wonder if the high frequency information signal on the track really gets to the rotor of an engine. I expect the rotor is really fed with a DC signal.
Maybe the problems in the collector are caused by semi-short-circuit caused by dirt accumulating between the collectors?
C and M track; CS1R and 2 MS
H0 Offline
#5 Posted : 11 June 2010 22:26:55
No, it don't.
Not true DC. The decoder uses PWM (pulse-width modulation).
Current ESU decoders support frequencies between 15 kHz and 40 kHz - higher than the frequency on the track.
Older decoders use lower frequencies.
Depending on the speed, shorter or longer spikes of the full voltage (can be more than 20 volts) are sent to the motor.
"Me transmitte sursum, Caledoni!"
kariosls37 Offline
#6 Posted : 11 June 2010 22:33:14
The rotor is fed with DC current at the maximum voltage. to obtain anything else than top speed, the motor is pulses of current, with the same net. effect on the motor speed(the more time between the pulses, the slower the rotor goes)
The neat thing about the pulses is that the decoders with "cruise control" measure the back-EMF in the time between the pulses to figure out how fast it is going.
On some decoders, you can alter the frequency of those pulses, in order to reduce motor noisget better runing characteristics.
I suspect that the damage is done to the rotor when a pulse of current has just switched off. because of the coils in the rotor, a voltage builds up which then creates sparks which do the damage to the rotor
intruder Offline
#7 Posted : 11 June 2010 23:37:10
I have had the same problem on one locomotive only.
That was in my Br80 from the Junker aircraft transport set 2866, but after conversion to 5-star motor with Märklin's conversion set 6090.
I do not what actually happened, but I think the motor first overheated, making the plastic under the commutator to melt. I'm not sure why it overheated. maybe an error in the rotor.
I repaired the locomotive by replacing the rotor and the brush cover.
Best regards Svein
member of MFDWPL
Märklin Model Railway, the perfect recovery
www.saebonet.com
river6109 Offline
#8 Posted : 12 June 2010 06:23:09
When you've changed the reversing unit with a decoder, did you change the brushes ?
Make sure your wire connections from track to Central unit 6021 is correct.
Make sure all wires have been re-connected to the brushplate.
I have had locos for almost 60 years and never experienced anything like this before.
Yes there can be dirt accumulated between the gaps of the rotor, yes, you could of damaged one of the wire connections going from the armature coil to the armature plate, but having the same problem with another loco is also very unlikely unless it is a fluke you've damaged both armatures when converting the locos.
At one stage, brushes came onto the market for the drum collector (soft compound) but I've never heard a motor being fed with brushes from the front (1 copper, 1 graphit) caused a problem.
another problem could arise by over oiling the front of the armature, causing it to make contact between the isolated plates.
http://river6109.fotopic.net
#9 Posted : 12 June 2010 11:28:38
Hello to all!
I see that this topic is rather interesting one as there are many replies to it. I ma very thankful to you all on your comments and possible cause of damages on the armature...
Here I want to add something.
First, every time when I cleaned the motor, I replaced the brushes with the new ones and specially when they were worned out completely.
Second, when I converted my models to digital system, everything was changed except tires. That means that the brushes was also replaced with new ones.
Third, armature was thoroughly cleaned and no dirt was allowed to stay between two rotor sectors. That is something that must be done to prevent circle fire on the copper plates and prevent heavy damages of the same.
Sometimes, oil gets to the armature but it is rather small amount so it vaporized very fast and I am trying to avoid that every time when I put some oil to the side where the brushes are and copper plates of the armature.
Also, all wires that goes to the motor from decoder are checked and also wires which goes to the bulbs (which I use only from time to time in a try to save them...now, I have installed resistors to lower the voltage that goes directly to the bulbs, so, now, there is no problem to use them as I used to).
The problem is that the very same thing happened to the second model with LFCM rotor E94. That is something that really made me worried...
However, so far, all other models equipped with the same LFCM motors are holding very well and such damages are not visible nor they exists. But, two of them (Rc 1010 and BR216) started to behave just like these two with damaged rotors as well. That really makes me worried.
They are not running as they used to and they can hardly achieve maximum speed of the prototype (which is not too fast - for Rc1010 is up to 140 km/h which is used but rarely and 120 up to 130 km/h for BR216 which is also far from very fast running locomotives).
The wires that goes to the 6021 are Ok and I did not noticed anything unusual...I am using analog also on the same tracks but isolated (of course) and everything is working without problems.
The only thing that I noticed was pulsating of the CV number on the 6021. That pulses (brighter/bright) are not something unusual for 6021. Transformer is digital one and, also, nothing is strange going on with it as well...That should not cause the problem to the model's rotors.
Still, I can not find the reason why this is happening but I do know one thing: if this cause the fear of using my models on the way I am using them usually, then, I shall quit with this hobby because it does not bring me joy of any kind but only worries and struggle to keep them operational and that also means completely empty pockets and in one moment, I shall not be able to maintain them so, one after another will stop running for rather long period of time and, perhaps, for good...
I hope that this will not happen!
Best regards to all,
Zarko Kristic
RayPayas Offline
#10 Posted : 12 June 2010 13:07:40
Hi Zarko,
Your last post is rather gloomy and pessimistic. Fortunately, old Marklin motors are easy to repair and new armatures are cheap and easy to obtain. Don't let this small problem spoil your enjoyment of a great hobby.
Ray from the Rock.
Mostly Marklin Era III & IV
Still using my trusty 6021
#11 Posted : 21 July 2010 12:24:18
Hello, river6109!
Sorry for asking the next few questions to You as I did not check the forum so often...
Now, You stated that You have had "some of your models that are 60 years old"...Now, my first question is how much time do You spend with your models?
The second question is did You use c80 decoders for converting your models to digital system leaving everything that was in the original state (the original rotor, stator, motor end shield, brushes)?
How much time did (do) You spend with such converted locomotives?
And the last question is how frequently do You use your trains: once in a week, once in a month, once in a year or You have layout and spend a lot of time with your models and frequently used your old models converted with c80 decoders?
I was (and still am) spending few hours once per week or, maximum twice per week...My models runs, in average, around 1000 km each per year in exact scale. Certainly it all depends which model is in use, for example, is it TEE or is it steamer... But, the distance is correct for all of my models.
The things that happened to me is quiet unbelievable and, to be even worse, mechanical flaws are shown on some of my models as well and those mistakes or errors or, you name it, are looking impossible to happen. For example, my BR151 electric locomotive has one of the transmission gears completely loose and it can be moved in all directions by hand. Certainly, that causes resistant to the motor and she is slightly warmed after some time of use. I wonder is this possible? Unfortunately it is.
Also, Marklin is making their models with errors in wheels assembling and transmission. Certainly, they are not all with those errors but some of them got to the market and the model shakes when running...and that is not so unusual for the Marklin, unfortunately. To be completely honest, although I am Marklin collector for 40 years, such things I have never seen on other models of other manufacturers (DC) such as Fleischmann, Roco, Trix (when they was independent manufacturer) and so on...
I trusted Marklin as one of the best, if not, the best manufacturer of the model trains in the World, but now, I see something that, simply, does not stand...
I shall remain Marklin fan and I shall collect Marklin but, I shall be extremely careful when I am giving my money for it as I expect adequate quality.
Thank You on your answers up in front!
With best regards to all,
Zarko Kristic
river6109 Offline
#12 Posted : 21 July 2010 12:46:51
Zarko,
If I read your 2nd last reply correctly, you add oil to the side of the brushes ?
This is a no-no.
You don't need oil unless the loco runs erratic or makes an unusual noise.
To your question regarding converting analog locos into digtal with 6080 decodrers.
I have done over 200 conversions and have never experienced anything like you describe.
Yes all the original parts and a thorough cleaning and all of my locos are still running (cogwheels)
regards.,
#13 Posted : 22 July 2010 10:24:21
Hello, river 6109,
First of all, thank You on your answers!
The oil is put on the side of the brushes on every model that I have. Just to be sure, in Marklin maintaining recommendations, You can see that one drop, or maximum two drops, of oil is needed to be put on both sides of the main rotor axle.
I put the oil inside the hole of the motor end shield every time when the model is about to be re-assembled. On the other side of the main rotor axle, oil is more than needed.
I had my old BR103 long time ago, and at a time, I did not know anything about maintaing locomotives, so I did not put any oil on either side of the main rotor axle. So, what happened? The main rotor axle wider the hole in the metal body that carries main transmission! Is this possible? Yes, it is very possible although the alloy from which is made the main bogie transmission is very hard to be warned out, even if you use "Black&Decker" drilling machine! But, this small steel axle, which is almost 100% smooth, can and did, wider the hole in the metal body of the main transmission box (bogie). This is something that I shall never allow to happen ever again as the lesson is learned on the hardest possible way!
I know that this sounds just "incredible" and "impossible" but this is true! I have sent that bogie to the Webmaster of this forum so he can confirm this statement and, attach the picture of that bogie so everyone can see it. To me, it also seems completely impossible, but, it is not...unfortunately...
Regarding the flaws in manufacturing, it is not that rare...
Regarding the life time of the motor, it all depends how you use your models or better, how much time you spend with your models. One is certain: c80 and LFCM as well as SFCM motors are not made for digital operation as their life is dramatically shorter. The LFCM and SFCM motors suffer higher voltages then 16 V that they are made for and that is, simply, "killing" them...
To me, permanent and final solution is to convert them to 5 star motors and finished with that for good. I shall keep some of my models as they are just to save the "spirit" of LFCM motors as they are not that "rigid" in comparing with 5 star motors, but, they also looses a lot when HAMO magnet is installed (certainly, steady magnetic field causes motor to stop running instantly), but, for me, they are running smoothly and acceptably...
The only thing which will come sooner or later, is tremendous warning out brushes. When that starts to happen, the time will come for them to be converted to 5 star as well. Simply, there is no other solution. For me, there are two solutions: expensive and even more expensive. Expensive solution is to install 5 star motor and even more expensive is to replace the rotors with the new ones and then to install HAMO magnet and appropriate decoder, and, to be honest, that is not final solution at all. Also, there is one even more expensive and that is to replace the motor with Faulhaber motor already installed on the main transmission bogie.
Well, thank You all on your help and attention regarding this topic!
With best regards and wishes,
Zarko Kristic
Hemmerich Offline
#14 Posted : 22 July 2010 11:39:32
Zarko,
I can confirm you that this collector problem shown by you also occurs/red on purely analog driven models which did not contain any digital parts/decoder. Wink
This posting might be subject to change or removal at any time.
arconell Offline
#15 Posted : 27 July 2010 00:13:03
Hi Zarko,
Yes indeed this can happen. What's more: it will happen if proper maintenance is long overdue.
First you have to realise that running on digital wears out the brushes much faster than running analogue, because of the PWM frequency. It does not affect the coil windings but read on. Your problem was caused by brush fire.
Brush fire is caused by:
Regularly running the loc on high speed or max. speed while the capacitor between the brushes is lacking or broken.
Separation slits between the collector sectors getting filled up with sticky carbon/copper dust (sticky because of oil getting on to the brushes/collector).*
Bent or distorted brush springs and/or worn out brushes causing a less than optimal contact between brush and collector.
Generally a dirty engine and/or dry running gear. (causing very heavy engine loads)
*Can easily be cleaned by scraping the dirt out with a pen knife.
(looking at the photo this is what caused the failure in your case. You can see the burn marks across the slits)
Brush fire (continuous sparking) causes the collector to overheat and left to itself will eventually lead to a complete melt-down of the whole rotor.
Keep in mind that even the old L/SFCM's are precision engineered miniature engines running at very high revs. Like any engine they need some regular maintenance, cleaning and TLC if you wish. Provide those minimum needs and they will run forever.
As was suggested by others in this thread: MAKE SURE NO OIL GETS ON THE BRUSHES OR COLLECTOR!! If it does, clean the rotor and replace both brushes.
Good luck, Robert from Niederrhein/Germany
#16 Posted : 28 July 2010 13:31:00
Hello, Hemmerich, Robert, all!
I just want to say thanks to Mr. Hemmerich whose statement calmed me down a little bit. Thank You!
Here I want to add something. I have replaced the rotor on my E41 and she ran like never before (so fast that I can hardly recall when she was running like that) still, I noticed one problem: motor's temperature is high!
I put new brushes, cleaned the motor, remove oil from the places where it should not be, no oil on brushes (I have never put the oil on brushes directly nor indirectly, but some amount got to the rotor sometimes but it is rather small amount of oil so, it should not be a problem), cleaned transmission mechanism and put additional capacitor directly to the brushes.
Still, the motor is heating and to be honest to the end, the motor always heating even 36 years ago as far as I remember. Now, with the completely new rotor and brushes, motor is heating again. Temperature comes from the brushes - sparks and the rotor is new so there was no dirt nor oil between collector's sectors at all. Brushes are not filled with a single atom of oil and I still have sparks that heats the motor and the rest of the story is well known.
But, I hope that this new rotor will last. Now, the only problem is the brushes. They are worning out just too quickly and I noticed it on my BR103 which runs perfectly and no overheating whatsoever, but she "consumes" carbon brush just too quickly...I am not running my trains above the prototypical speeds and I shall run my E41 at maximum speeds between 100 and 120 km/h. I hope that this will not cause collector to be worned out in a couple of years and I also hope that the brushes will last a little bit longer (smaller sparks, longer life of the brushes as well).
Robert, You are probably right because when the model is unable to reach the maximum speed at lower voltage, the voltage is increased by me in a try to reach maximum speed (for example, for my BR216 it is between 100 and 120 km/h) and then, the problems came. As You said, brushes started to worning out just too quickly and motor is warm as the direct consequence of the sparks, again, caused by the higher voltage...
I have my own data base and I can see how many kilometers each model ran and when. According to my own data, I can clearly see that the brushes life got just too short, specially after I have converted the model into digital. I was suspected at the high frequency of the digital current so I came to the conclusion that LFCM/SFCM motors are not made to be used on higher voltages then 16 V nor on higher frequencies. They should be replaced with 5 star rotors...But, in order to save the "spirit" of the old motors, I have decided to leave some of them as they are and replace them on places or better, in models that runs faster then 120 km/h such as E10, Rc 1010, BR103 and such...If I use one model more often then the others, I should replace the motor in it so I shall not be in position to loose the money for brushes as I really do not want to open/shut/open motors every time when I use them. That does not make any sense.
I am fully aware that rotors are small and that revolutions are rather high per minute and that I must give them proper maintenance on time. But, I just can not do that after each usage when the model ran for 300 or 400 kilometers only which means that she was on tracks maximum for 4 hours.
I shall do my best to avoid high voltages and high speeds as much as I can, but, some models must be fast on request. Well, I really hope that I shall avoid total collapse of my older models and I shall do my best to replace the motors only in the models which are critical or in frequent use.
Once again, thank You Robert and thank You Mr. Hemmerich on your answers and help!
Oh, yes, by the way, I found one interesting discussion about, almost the same topic on John's Oxlade web page and the question is almost the same but considers Faulhaber motors. Now, if anyone knows what kind of warranty Faulhaber gives for their motors and how many hours they can stand running on tracks?
Once again, thank You all on your time and attention!
With best regards,
Zarko
arconell Offline
#17 Posted : 28 July 2010 17:27:30
digitaltrainshort wrote:
.....According to my own data, I can clearly see that the brushes life got just too short, specially after I have converted the model into digital. I was suspected at the high frequency of the digital current so I came to the conclusion that LFCM/SFCM motors are not made to be used on higher voltages then 16 V nor on higher frequencies....
Hi Zarko,
The motor gets warmer on digital at any speed because the real motor voltage is usually around 20 Volts, constant. Speed control through PWM, which the decoder uses, "chops up" the voltage leading to the motor in small parts and when you increase speed, more parts are sent to the motor. This causes the motor to get warmer then with analogue where you would actually vary the voltage itself for speed control. However this is not a problem for DCM or L/SFCM motors or their rotors so long as they are in good condition. The brushes wear out quicker because of the high frequency the decoder uses to chop up the voltage and because these voltage parts have a rectangular shape, not a sinewave shape, causing the drop and rise in voltage during one part to be extremely quick. The voltage and hence current bursts follow in quick succession and each burst heats up the contact surface between the brush and collector with a higher chance for sparks to appear.
Therefore on digital the spark suppression, done mostly with the capacitor (yellow disk-shape)that is mounted between the brushes on the motor shield and to some extend also through the capacitors between mass and each brush is of extreme importance for longevity. However, capacitors do have a tendency to slowly loose their capacity during use and in time. More so when they are subjected to heavier loads as is the case after a conversion to digital.
If you have the possibility to check them, you should do so, otherwise renew them I'd say every 2-3 years. That way you are sure to have optimum spark suppression all the time.
Another thing is this basic voltage of 20 Volts on the track. Most people use this, simply because they're not aware of the fact that the 16V AC(17V really) of the Marklin transformer is rectified to 20 Volts DC on the track by the Central Unit. I am not familiar with the 6021, but if there is a built in output voltage regulator, put it on the lowest setting. Otherwise you might consider getting another transformer for feeding the 6021 which gives off say 14 Volts. This will lower the basic voltage to some 17-18 Volts on the track, which is quite sufficient and will make everything, including the lamp bulbs and brushes, live longer.
Don't worry too much about the high speeds, so long as the motor is in good shape it can easily take it, but if you notice a loc going slower at the same speed setting, check it first instead of turning up the speed control.
Best regards, Robert
RayPayas Offline
#18 Posted : 28 July 2010 18:01:41
Zarko,
One factor not much mentioned in this thread is, of course, total number of hours run. I was actually quite surprised when you said how many hours you got out of your locos. Four hours of continuous running is a long time for a tiny motor. Doing this once or twice a week at high speed is definitely going to cause a lot more wear than I'm used to seeing in my locos.
Ray from the Rock.
#19 Posted : 29 July 2010 11:01:06
Hello Robert, Ray!
20 volts on the collector all the time (chopped, of course) is something that I did not know. It is, than, normal to loose brushes and rotors so quickly...unfortunately...old ones, of course...
I can add resistor to the output of 15 Ohms 1/4 of Watt to reduce output voltage to 16-17 Volts in a try to save brushes and rotors. This is great idea and it can help. We shall see what I shall get with installing the resistor.
Regarding capacitor directly connected to the brushes, I have installed one over the existing one, but I did not notice any chaingings. It is possible that capacitors on my older models are gone and I shall try to check them out.
Regarding the hours spent on the tracks running, all I can say that it is summary of all runnings from point A to point B. Maximum distance that my train is covering is between 100 and 120 km in exact scale at once. That means that the locomotive can spent an hour or less then an hour if she is running faster then 100 km/h. Also, she can spend more then an hour if she is running less then 100 km/h (mostly steamers). In one day, my train(s) can run up to 400 km depending on the train specification. If it is TEE or IC, then, they can cover that distance in one day. Others, however, hardly, as this distance requires more time which I do not have enough.
I am using my trains once in a week or, maximum, twice. When I determine starting point A (starting station) and B (ending station), the journey can begin. The same train could stay on tracks for months as it just can not pass that kind of distance(s) just in one single day and that is, how I call it "killing the model" fast if they are running that much in just one single day. I am not "playing" that way. After the train covers 100 km, I stop it at the passing through station for 2-5 minutes for security reasons.
However, I had a friend who was train collector as well and who passed away too early, who runs his trains exactly according to the real time table! So, if the train is traveling from Hamburg to Munich as TEE, his model will travel at the same route in the real time at prototypical speed until it gets to the final station and that is Munich or point B. He has so much patience that he ran his train(s) for the whole night and finish the route in the morning at the exact time when the real train did the same. I have to add here that his BR103 was Fleischmann's model and she ran like a wind. At this moment, the same model is in my possession and she is fully operational and magnificent model. I am doing the same, but not in one single day...
So, there is nothing unusual in that...I am not using my trains like my friend did, but, I was able to see how DC models behaves in those, I can freely say, extreme circumstances. I must add here that he did not have any kind of problems with his trains, but, also, he did not use digital system as well.
So, all the problems started when I converted my LFCM/SFCM locomotives to digital. DCM locomotives are running just fine and I do not have any kind of problems with them. Also, my analogue models are running like a wind.
Thank you Robert and Ray and all the others on very useful informations in an effort to prevent loosing xFCM motors too quickly!
With kindest regards,
Zarko
arconell Offline
#20 Posted : 29 July 2010 12:03:32
Hello Robert, Ray!
Hi Zarko,
I'm afraid it won't work with a 1/4W resistor, you will blow it to pieces. Your transformer (if you use the grey 52 VA Märklin one) delivers 52VA which depending on the load factor while feeding the Control unit is close to 52 Watts!! Generally, using a (series) resistor to reduce the voltage on a transformer is not a good idea. It is better to use another transformer with a lower output voltage rating. Just as an experiment, you can use for instance the Märklin 6646 transformer and feed the Central Unit from the red and brown rail connections. By turning the knob you can adjust the input voltage any way you like without risking overvoltage so long as YOU DON'T USE THE REVERSE COMMAND. You will only be able to run 1 maybe 2 trains at the same time that way but you will see the effect of the reduced voltage immediately.
Secondly, you put an extra capacitor parallel to the existing one. That doubles the capacity. Usually and as far as I know Märklin puts in a 270 pF ceramic capacitor, You have now doubled the capacity, which for spark suppression shouldn't make all that much difference but it may interfere with the speed control. If it doesn't you can leave it like that or (better I think) replace the old capacitor with the new one.
Good luck, Robert
Ps: You won't notice an immediate difference with the capacitor, at least not in terms of running characteristics or warming up of the motor. If you want to see the difference in spark suppression run the loc without the body (motor visible) in a completely darkened room.
H0 Offline
#21 Posted : 29 July 2010 13:34:13
DIP switch 4 on the CU 6021 can be used to reduce the track voltage (ON: reduction, OFF (default):no reduction).
#22 Posted : 01 August 2010 12:45:32
Hello, Robert, all!
Well, I was just thinking on the resistors that I currently have and I have just written down what was on my mind at that moment without any thinking.
No, 15 Ohms 1/4 W will be burnt out in a second if I connect it directly to the motor (decoder outputs) or to the tracks...So, no experiment in that way was not done.
On the other hand, DIP switch 4 on the Control Unit 6021 is not recommended to use and I tried it already but my 6021 was getting hotter and hotter in a matter of seconds, so I turned it off and returned everything on the previous settings and everything was just fine...It looked like that 6021 is in a short circuit but, no visible shorts are noticed...
Using analogue transformer is acceptable, but, my personal opinion is that I must go to 5 star motors and replace all critical motors which are in certain models with it. Brush consumption is rather unbearable and it will take my money out of the pockets and nothing will be solved.
Also, old rotors are not cheap at all and I do not want nor I have any intention to experiment with them how long will they stand undamaged spending bunch of brushes just to prove something that is more than obvious...They are not for digital operation. At least, they can not stand the way I am using my trains...With analogue, I have not that kind of problems and all analog models (except ones with DCM motors) will not be changed.
Little by little, I must replace my old motors sooner or later...
Thank You all on your useful informations and suggestions!
Zarko Kristic
#23 Posted : 03 August 2010 13:13:03
Hello, Robert, all!
I have just tested my E94 on both systems using digital and analogue. It is proven that the motor heats much faster on digital then on analogue. So, there is no doubt about it at all...
I shall see to install new capacitors to it and then to see how will it behave. Sparks should be smaller or at least reduced and that is vital!
I shall use 270 pF 16V capacitors and see what will happen then...
I shall inform You about the experiment soon!
With best regards,
Zarko
Renato Offline
#24 Posted : 04 August 2010 11:17:07
Hi Zarko,
I suggest you to use capacitors with higher voltage (I think 16V is too low...).
Bye
Renato
arconell Offline
#25 Posted : 04 August 2010 13:34:54
Hi Zarko, Renato,
Renato is right, a 16V capacitor has too low a rating, I would choose 100V. After all, the capacitor has to kill the sparks which may at the point where they occur, between brush and collector, have a voltage >1000V. That voltage won't reach the capacitor because the capacitor is meant to prevent the sparks from occurring. On line voltage electric motors usually capacitors are used with a rating of double the line voltage. Here that would translate to 40 or (more common) 50V rating. Or use the capacitors Märklin provides.
As to the warming up of the 6021 on DIP switch 4 setting "ON", that is both good and bad news. It tells you that the 6021 has a stabilised booster which is good, but it is also the reason that the supply voltage from your transformer should not be higher than Vdc(output of 6021) / 1,3. If it is, like with a 16 Volt transformer on setting "ON", the excess supply voltage is simply "burnt off" in the form of heat.
Another thing, the motor does get warmer under digital operation then it does under analogue, specifically under slow to average speed or high load. Simply because at lower speeds you are still supplying it with the 20 Volts under digital and hence it operates with high current pulses. That is why I suggested to reduce the track voltage. However, exchanging a 3-pole for a 5-pole rotor will not make any difference, at least not in warming up or life time of the rotor. It may make the loc run a bit smoother at low speed but that will be the only difference.
One last thing, as I have said before, brush life is increased both with a lower track voltage and with a lower PWM frequency on digital. I don't know what the PWM frequency of the 6080 decoder is, Märklin doesn't have that information available, but I would guess it is somewhere around 1 kHz. On analogue it is of course 50 Hz (or 60 if you are f.i. in the US). I know of only one decoder that can run DCM and L/SFCM on 60 Hz PWM. That is the Tams LD-W-32 or -33. They cost around € 13-14 nowadays. You can directly replace a 6080 with these decoders without any motor modifications. Programming of these decoders (address, running variables such as min/max. speed, acceleration and braking delay etc.) can be done with the 6021. They don't have load regulation but neither has the 6080. Installed and programmed correctly (which takes some time and effort, certainly the first time) they make your loco's run better than with the 6080.
Best wishes, Robert
#26 Posted : 04 August 2010 15:11:56
Hello, Robert, Renato all!
I have just installed four capacitors in two of my models E41 and E94. The capacitors are 270pF at 16V.
I did test runs and the results are more than obvious: motor is not overheating at all! I can say that it is slightly warm but not even close to the temperature that I had previously on the same models. That clearly shows that capacitors are extremely important in this case and You were right about this! I just want to say thank You very much on your help! Now, I shall see how it will behaves in the future with current capacitors...
Regarding capacitors of 50V and higher (same capacity) I can try and see what will happen then...
When I get those capacitors, I shall try them and let You know (and to all members of this list as well)!
Until then,
Zarko Kristic
#27 Posted : 09 August 2010 10:31:23
Hello Robert, Renato, all!
I have replaced the capacitors on E41 and E94 with the new ones. The capacitors have the value of 270pF 100V. The effect is not quiet visible but the motor is not overheating in the way it did.
I must add here that both models have brand new rotors and brand new brushes. They have passed test runs and brushes did not even "move" regarding wearing out. So, this could be because of the brand new rotor and also because of the new capacitors as well. But, so far, I am satisfied with the behavior of the models.
However, I found on one place that the capacitors could have the value of 1 microF and 35 V! The information is not to be trusted in 100% as it could mean something completely else and not regarding on those specific capacitors.
Well, the rest, only time can tell...I must add here that E94 was on tracks for around 10 hours and E41 around 6 hours...
Zarko Kristic
dntower85 Offline
#28 Posted : 09 August 2010 19:35:09
Thanks for the update Zarko,
I may try this capacitor on my v200 as it tends to ware out the brushes faster and the drum gets dirty faster than my other locos.
DT
Webmaster Offline
#29 Posted : 09 August 2010 20:35:33
In eg the 60903 kit the ceramic capacitor is marked "102", which means 10 picoFarad + 2 zeroes = 1000 pF = 1 nanoFarad.
Ceramic capacitors are more durable (wide voltage/current span) than polyester ones, so they have no voltage rating.
So I think you should go for 1 nF (bigger value means lowering the high-frequency load on the motor, since it shorts out lower frequencies than a 270pf does) and try to get ceramic ones.
arconell Offline
#30 Posted : 10 August 2010 00:14:53
Hi Juhan,
In principle of course you're right about capacity and high-freq. absorption. However, the goal here is spark absorption. The low PWM frequency already being reduced to a ripple by the relatively high (series) induction of both rotor and field coils in Zarko's case (series motor with 6080).
The 6090 uses a much higher frequency on a smaller induction (only the rotor, field coil being replaced by a PM). So they upped the capacitance.
in Zarko's case the sole purpose is spark suppression, and since sparks have an extremely high frequency anyway, the 270 or so pF is quite sufficient for that purpose. Obviously Zarko has already doubled it in some experiments and didn't see any effects on the control characteristics. Doubling (or more) the capacity will have very little or no effect on spark suppression however it will give the decoder an added capacitive load, which the 6080 decoder output stages will not necessarily take kindly. That of course depends on the design of the 6080 which I am not familiar with but based on my knowledge of medium to high freq. power semiconductors of that design era, I tend to be careful with capacitive loads when the circuits are not designed to handle them.
#31 Posted : 13 August 2010 11:52:19
Hi Robert, Renato, all!
I have just finished with the experiment regarding the capacitors and their role in sparks suppression on LFCM/SFCM motors...
The experiment was done on my BR216 with LFCM motor and which rotor is not in good condition (consumption of brushes is abnormal).
I used all ceramic capacitors with various capacities: 270pF 16V, 270pF 100V and 1nF. I also used brand new 600300 brushes.
The results of experiment...
I got various results, but, one conclusion: no matter what capacitor you use, you just can not prevent sparks on the collector at all if collector is not the new one! So, what happened? First, motor overheated (capacitors 1nF), decoder overheated, motor overheated (capacitors 270pF), abnormal consumption of the brushes stayed...
In a just 6 hours of running, the motor "ate" 65% of carbon brush and 70% of brass brush!!!...and that is highly unacceptable in all ways!
I even tried combination with three capacitors in series but it did not work with HAMO stator at all. With normal coil field magnet, it works, but I do not know the consequences of such combination in a long run so I shall remove third capacitor just in case...
So, dear Marklin collectors, there is no cure if the rotor is damaged but to replace it with the new one. Also, that is not final solution. The final solution is to replace it completely with 5* motors and then, you will be calm in the long run!
I feel sorry for my old models that they can not "answer" on new "challenge" called "digital operation". On the other hand, I feel sorry for myself as I have lost, minimum, 600 Euros buying c80 decoders and installing them into models with LFCM/SFCM models...Sad
So, if you notice unusual consumption of brushes on your model(s), be ready to get DCM replacement or new LFCM/SFCM rotor on time as nothing can save it from total and final disaster...
With best regards and wishes to all,
Zarko Kristic
RayPayas Offline
#32 Posted : 13 August 2010 12:23:43
Zarko,
It still surprises that you have such a negative experience, considering that no-one else seems to have this problem to the degree that you quote!
All first generation digital models from Marklin were fitted with the 6080 decoder, and a large percentage of them had unmodified SFCM and LFCM motors, so that to say that these models "could not answer the new challenge called digital operation" is quite false. As well as the 6080 decoders there are a large number of Delta decoders out there, factory fitted into SFCM and LFCM motored locos. The Delta decoder is based on the 6080, and would behave the same way.
In my collection I have 14 locos with SFCM or LFCM motors and either 6080 or 6603 decoders. None of them show abnormal commutator wear, shortened brush life, or overheating.
Do you have any 36xx models which come factory fitted with a 6080? Are any of these a problem?
Ray from the Rock.
#33 Posted : 13 August 2010 15:13:21
Hello, Ray!
I am very sorry to say, but I am really using my models and that means they really run! I do not have negative thoughts or such towards my own models, as a matter of fact, I was really proud on my models in all ways or I used to be, at least!
But, since this started to happen on several models, almost simultaneously, I have started to put some questions to myself first and then to the others how to solve this unpleasant situation.
I really do not have anything against anybody whose will of using models is absolutely free, but, You must know that such things happens if you use it as the real models. Nobody has anything against keeping models in display (it is free will!), but, if you use them for the purpose as they was made for, then, you will faced the problems sooner or later.
Yes, there are a lot of models equipped with c80 decoders and I have one of them (BR86 originally mounted decoder c80 by Marklin) and nothing happened to her. Now, the question is why? I am using her only with four three-axle coaches also made by Marklin and that is all. In comparing with E94 or E41, those are so different roles that can not be comparable at all. I have my BR86 for 10 years and I did not change brushes not even once!...and she covers a lot of kilometers!...but, with very lite composition, actually, she does not feel it at all!
That is the reason why I am seriously doubt (and I have proves for that!) in LFCM/SFCM digital capabilities, specially ones equipped with c80 decoders.
I shall be endlessly happy that I did not see what is happening after some time of usage with LFCM/SFCM motors and I shall be able to save a lot of money for sure. Unfortunately, things are not standing that way.
As I said on the beginning, everything depends on how do you use your models and how many hours are you spending with them per day/week/month/year...
It would be great to hear opinion from someone from Hamburg Wunderland and their experiences regarding maintaining the locomotives and do they have, at all, any model equipped with LFCM/SFCM motors on the layout?! Also, what about some other manufacturers and their layouts such as "Schwarzwald Modellbahn" or "Losheim/Eifel" which has Roco's models on their enormously big layout or someone from US as there are a lot of people who has large layouts as well? What are they experiences? Are those models specially modified or...? If they are, what kind of motors are inside the models? That should not be the secret at all...
I have seen a lot of things until this very day and a lot of models made by other manufacturers. Also, I knew or I still know people who are running their models on the way as I do as well, but, I admit and that is something that really hurts me, I have never seen such things on any other model made by any other manufacturer! Certainly, I saw completely burnt out rotors, broken brushes (Roco - for example) and so on, but I have never seen that the gears fell off by themselves after some time of usage just like that! I have never seen such destroyed rotor's collector by brushes or by voltage, I have never seen (specially not metal ones) completely free gears in any other model made by any other manufacturer but Marklin...
Simply, using LFCM?SFCM on digital system is not recommended at least! I am collecting Marklin for almost 40 years and I shall not stop doing that, but, some things are not going together just like that...and I am still thinking that Marklin is one of the best model train manufacturer in the World!
Simply, things that are happening, should not happen at all (specially not transmission malfunctions and such...)...
Well, Ray, this is what I am thinking about this all. I do hope that I shall solve the problem, but, not by buying new LFCM rotors endlessly and endlessly buying new and new brushes all over again, but buying something that I should be able to lean on in all times (certainly, nothing lasts forever!).
Zarko Kristic
RayPayas Offline
#34 Posted : 13 August 2010 15:54:44
Well, good luck, Zarko.
I don't know what the answer is to your problem, but I can certainly say that I don't accept your conclusion that these motors and digital don't go together, as I have plenty of them and have no problems at all. And no, I don't keep them in a glass case, I run them regularly on my layout.
Maybe you should just accept that you run them too hard and too long and accept the consequences!
I hope you can come up with some way of running them which gives you less problems, but I don't see that the problem is with the motors.
Ray from the Rock.
#35 Posted : 14 August 2010 10:52:16
Hello, Ray!
Unfortunately, I must add here that my BR216 is lost for the moment due to abnormal consumption of brushes. I just can not use her anymore until I replace the motor or rotor at least.
The rotor on BR216 seems to be in good condition unlike ones from E41 and E94, but, the consumption of brushes in just 6 hours of running is just unacceptable for me. So, she will wait for some time in display. I shall do my best and replace it with 5* motor.
I must also say that LFCM/SFCM motors was made to run under 16 V maximum and that was long time before digital was introduced. But, Marklin maybe, knew that the consequences of using such motors on higher voltages (technical stuff) can shorten their lives dramatically, but they was just too fast to supply the market with new system and get the money fast. Well, this is only a part of speculations of course, but, 16V motors can hardly last the same period of time on 22V and that is the fact.
I shall get out of this situation this way or that way for sure, but this should not happen.
And, one more thing: the capacitors on LFCM/SFCM motors are 270pF ones (original Marklin capacitors installed on LFCM motors and c80 decoders!).
Thank You Ray on your suggestions and possible solutions and for participating in this discussion!
With best regards and best wishes to all,
Zarko Kristic
john black Offline
#36 Posted : 14 August 2010 14:48:56
I must also say that LFCM/SFCM motors was made to run under 16V maximum and that was long time before
digital was introduced ... they can hardly last the same period of time on 22V and that is the fact.
Hi Zarko,
point taken - agree, Sir!
That's why I built two levels on my layout - an analog one for my classic beauties, and a digital level for nowadays' stuff. Works perfectly nice Laugh
And congratulations on your most interesting topic ThumpUp
AT&SF, D&RGW, T&P, SP, WP, BN, NYC, ARR, epI-III - analog & digital Marklin Classics only.
Webmaster Offline
#37 Posted : 14 August 2010 22:35:57
You don't have 22V to the motor in digital. The track voltage is insignificant in digital operation regarding the motor power feed.
The track voltage is seen by the decoder as a pulsed DC digital signal as well as the power source for the loco/decoder. The decoder reads the overlaid signal in the +/- 20-22V varying square pulsed DC on the track and converts the information in the signal - using the raw voltage supplied for power - to produce a pulse width modulated (PWM) 12V DC output to the motor.
The pulsed 12V DC is approximately the same as about 16V AC regarding motor feed, but much more "edgy" since it's more kind of a series of on/off DC power feeds than a smoothly edged sinusoidal AC. This may strain the mechanical contact surfaces a bit more with flashes and arcs than analog operation, at least as I see it.
Zarko's problem is real, but the reason behind it is a bit complicated...
kariosls37 Offline
#38 Posted : 14 August 2010 22:49:06
It may be interesting to see what the conditions of the train room and affected locos are: is it airconditioned? dusty or not? are there any direct connections to the outside?. On the affected locos, you might want to check rolling resistance(push the loco, without rotor, over a glass pane. the wheels should turn)
For example, high humidity may encourage arcing across the brushes and a heavy running gear train may overload the motor.
It may just be that it is a combination of factors that are at the root of the cause
arconell Offline
#39 Posted : 15 August 2010 01:06:34
I'm afraid that is not correct for any decoder I know, certainly not for the 6080 Zarko uses. The 16V AC full-wave rectified to 22V DC minus the semiconductor losses producing some 20V DC is turned into a PWM control DC voltage, the peak of the squares being around 20V which goes directly to the motor. With modern load compensated decoders you can change the input voltage (booster output voltage) and it will reduce the peak of the squares going to the motor accordingly, however you'll only notice that from a slight dimming of the lights, there won't be any speed changes because the load compensation just makes the "duration" of the squarewave longer, thus increasing the net current at a lower voltage. Just turn off the load compensation and you will notice the speed difference!
Hence my earlier suggestion of using a lower supply voltage. That will make your motor and brushes last longer. I run at 18V track voltage, off a voltage regulated 8A booster and on all my old S/LFCM loco's the brushes (standard Mä issue) last between 30-50 hours with in-between collector cleaning/maintenance every 20 hours Or every 3-5 years or so.... They run on a 50 Hz pwm, low frequency and lower voltages save brushes and collectors.
#40 Posted : 15 August 2010 11:07:40
Hello kariosls37, Robert, Ray, Juhan!
I want to give some answers here to some questions. I do not think that is something wrong with the motors themselves as well, so I agree with You Ray in this, but I think that it is something wrong with the digital power or better, old motors can not stand it for longer period of time or even better, their lives are shortened. I am saying this because my BR216 is "only" 15 years old and it was brand new locomotive when I bought her and I have installed c80 decoder instantly, which means from the day 1. That period of time is just too small for the model to last in comparing with all other models. Also, I did not use her every day and she was running on usual distances nothing special and not too much. But those symptoms started to appear very fast and in the end, she is standing in the display waiting for the new rotor or, which is better solution (if I want to use her on digital system) 5* motor.
The only difference between You and me might be the difference in using models and that is why You did not have or had such experience and I wish You to never have!
kariosls37...There is no humidity in the room and the room is not air-conditioned. I am not using my trains during Summer because of the high temperatures that affect to the models as well. When I was working on those tests on my BR216, outside temperature was more then acceptable, 24 degrees C. Yesterday, I let my trains to run for a while and I have noticed that motors heated unusually on analogue locomotive (nice Austrian OBB green locomotive) and on E40 equipped with 5* motor (on digital system), so I stopped the trains after very short period of time.
So far, I did not notice any kind of resistance (mechanical) on the "problematic" models, but it is good tip to test the mechanic characteristics on the glass! Thank You very much on this tip!
Hello, Robert! Unfortunately, I do not have such decoders as a spare parts so I can replace current ones with them and reduce the voltage on the motor that way. Now, can You tell me what kind of booster/transformer do You use for voltage supply of your tracks?
I must add here that I noticed this damages when I noticed that I had to change brushes on the locomotives that I use, almost every time when I took them out of the display and then, I took a look at my data base which shows how many km did the model ran, when the brushes was changed (the date) and when I used particular model last time. So, I noticed that it was just too often, almost every time when I took it out of the display...That started all this and I noticed damages on the rotors. Also, changing in speed was very suspicious so, I found what I found on the collectors surfaces on four of my models and that, really, horrified me...Sad
As I have replaced the rotor on my E41 and E94 with the new ones, I shall see how they will behave. I must add here that E94 was something more then 8 hours on the tracks already without any changings in brush conditions as well as E41. I shall see how they will behave in the future...
...and, thank You John on your support to this topic!
Zarko
GSRR Online
#41 Posted : 15 August 2010 12:41:46
Zarko,
Interesting topic. I'm curious, what is your mains voltage? 220, 230? Have you checked over a period of time that it is constant and within tolerance? Do you route your power into your home through a surge protector or something similar? Have you exchanged the transformer for another? Any problems with electric appliances in the house?
Thomas
HO Era III (late) Diesel Electric Steam Freight German USA C & M Track MS Digital ETE-ENE
sudibarba Offline
#42 Posted : 16 August 2010 03:00:57
I would like to jump in on this topic but like Ray, I have no problems. Of course, I don't run my Loks 6 to 8 hours straight.
Why would you do that? Anyway, this topic seems to only be driven by the originator. No one else seems to have a supporting issue.
Anyway, brushes are cheap and rotors are $25. on a much more expensive Lok.
Now, I do seem to remember that Scott Houseman, of Helmutshobbies.com warned on his web site that digital Loks had to be cleaned more often to avoid decoder failure. Check out his web site.
Eric
arconell Offline
#43 Posted : 16 August 2010 10:18:33
Hi Zarko,
I run all my L/SFCM loco's with Tams LD-W-32 or LD-W-33 decoders. However, the voltage is not dictated by the decoder but by the command station and its power supply, i.e the transformer that feeds your 6021. The 6080 decoders work the same as these Tams decoders. I would not advise changing a 6080 decoder so long as it works.
I wrote this earlier:
Try to find a transformer with an output (secondary) voltage of 12 or 14 Volt, capable of delivering a min. of 5 A, that is 60VA (Conrad www.conrad.de in Germany has such transformers but you can find them in many other places) and hook that up to the 6021 with DIP switch 4 "ON". Just to make sure, with a lower voltage on a dirty track locs will stall a bit earlier than with a higher voltage. So make sure your tracks are really clean. (This is the main reason why manufacturers went to a higher track voltage with digital, because digital is more sensitive to dirty tracks than analog)
Robert
#44 Posted : 17 August 2010 10:55:59
Hello to all!
First, I want to answer on few questions and comments...
Thank You Robert on your help and advise! I shall see what can I do regarding transformer with desired characteristics!...and thank You on the information about Tams decoders!
Eric, I have never ever ran my trains for 6 to 8 hours straight. I was talking about total running time, nothing else. My models can run (per one or two days per week) between 2 up to 3 hours maximum and not 2 up to 3 hours straight! In total, including stops, they could run 2 up to 3 hours...sometimes, and that is rather rare, they are running something above 3 hours and that all depends on what kind of train is on the tracks: cargo or passenger or both. Passenger trains run less, cargo more because of their maximum speed which is from 60km/h up to 100km/h (but rarely). So, no straight runs of 6 or more hours! Thank You on the information about spare parts! Yes, not so long ago, I have to clean the motor of my E40 (5* DCM)because I noticed that the motor heated a little bit more than it used to. So, I opened it and found out that motor (collector) and other parts must be cleaned. I shall check the site that You gave the address of!
Thomas, I have pretty much steady voltage of 230-240 V which is today's European standard. I have only one extended power cord and that is all. No voltage drops from that side. No, I did not change the transformer but I measured the output voltage and it is 21-22 volts which is normal for digital operation. No voltage fluctuations of any kind...and, no, I do not have any problems with electric appliances in the house.
Now, I have some interesting data regarding the voltage that came to the motor or to be precise, from the decoder (in this case it is c80 and c81) to the brushes. I have measured the voltage that comes to the brushes directly from the decoder (c80 and c81 in this case). The universal ampermeter shows clearly changing of the voltage values as you turn the speed knob from lower to higher speeds! The ampermeter was attached to the motor brushes, connections was going over the coil field magnet and to the right brush and the second wire from the decoder goes to the left brush over the choke.
So, here are the results of measuring (6021 control unit):
Speed knob position Voltage on the brushes (V) comments
50 8 acceptable
100 12 acceptable
150 14 acceptable
200 16
Warning! Voltage reaches its maximum value for LFCM/SFCM motors
250 21
Danger! Voltage crossed safety level! Damages of the rotor and brushes are possible to happen quickly!
So, as You can see, voltage on the brushes is not constant! It is pulse but the voltage itself does not go over the given level! So, there is no "constant" voltage whatsoever! At least, it is like that using c80 or c81 decoders! How does the DC pulses looks like, only oscilloscope can show and nothing else or other much more serious instruments.
Here are the values of the intermediate position of the speed knob on 6021:
Speed knob position between Voltage on the brushes (V) comments
0-50 6 acceptable
50-100 10 acceptable
100-150 13 acceptable
150-200 15 acceptable
200-250 18
Danger! Voltage lever cross the safety level! Damages of the rotor and brushes can be appeared quickly!
The results show that the voltage limits for LFCM/SFCM motors is when the speed knob is, at maximum, 200 (16 V on brushes). These are, if I can say like that, laboratory measures as there is no resistant of the rotor, transmission, load and resistant between brushes and rotor, but, this data is very valuable in case that you are using LFCM/SFCM motors.
So, I do not know what kind of instruments they used to measure constant voltage on the brushes (motor), but the ampermeter shows more then clearly that the voltage is not the same (constant) and that the voltage is directly regulated by the decoder itself. If You do not believe me, or if You do not believe me 100%, make your own measurements and use decoder(s) in the same way I did and that can be achieved by removing the brushes from their places if the motor is in the locomotive.
From this table, it is visible that possible damages of the rotor and abnormal brush consumption can appeared when the speed knob is turned to the maximum (21V) or between 200-250 position (18V).
Now, load and all other resistance was not included and that means that the voltage can cross the safety level earlier, but this shows the value of the voltage that decoder gives to the motor (brushes) directly.
So, what can damage the rotors and brushes so badly? If we add frequency and higher voltage (speed knob over 200), that could be the reason. Also, I admit, time can do its part as well...
So, dear Marklin collectors, this will be all for the moment.
I wish You all the best,
Zarko
RayPayas Offline
#45 Posted : 17 August 2010 11:35:56
Zarko,
The ammeter you used will measure average voltage and not peaks, so it is quite normal that you will see a variation as you turn the speed dial. The peak voltage will be constant at 20 - 22 V, and will look like square wave pulses on the oscilloscope. When the speed dial is at a low setting, the pulses will have short duration, and at a high speed setting the pulses will be longer. This variation of pulse width is what drives your motor slower or faster, and your ammeter reacts in the same way.
You seem to have set your own limit to what is a safe voltage for a flat commuator motor. Marklin have never said that the voltage on a motor has to be less than 16V. In fact, it is quite common to exceed it when you activate the reversing pulse, if your relay is not properly aligned. Obviously at this kind of voltage the locomotive will be screaming off down the track at great speed! This might give you an indication that all is not right!
Your own measurements show that the average voltage on the motor is only around 16V at the top end of the speed dial. Is this how you run your trains, at maximum speed? Maybe we have a clue here about your problem?
Ray from the Rock.
digitaltrainshort Offline
#46 Posted : 17 August 2010 13:19:28
Hello, Ray!
Well, I saw the look of the digital power in Marklin book called "Getting Started with Marklin Digital" and that, as You said too, is true. The thing that I did not know is that, model is actually, constantly running on those peaks. If the peaks are only "the peaks" then the digital operation with LFCM/SFCM motors would not be a problem as the "maximum" voltage for those motors is reached at 200. But, as the peaks seems to be constant, then it does not matter at all at what speed the train (locomotive) is running and those peaks are directly connected with the frequency of the digital power.
Yes, I know how analogue locomotives behaves when the reversing unit is not adjusted properly. And You are right: the locomotive starts to run like a rocket instantly (pulse of 24V). And, yes, Marklin did not say anything regarding that at all. Still, the locomotive does not run all the time at 24V as she stops and change direction of travel after a second or two. It is questionable how would it behave if the voltage can reach of 24V of constant power directly to the motor all the time (speed knob at maximum)?! This belongs to the sphere of speculations only, of course...
Well, no. See the table...Speed knob turned to the maximum (250) gives 21V on the brushes not 16V! 16V is given to the brushes when the speed knob is at the position of 200. I suppose that You just missed the adequate data because it is not shown clearly and I noticed it too late and did not notice formatting text on time. Sorry for that!
No. I am running my trains only at prototypical speeds. That means that, for example, E94 as a cargo locomotive, has its maximum speed of 90 km/h as the prototype so she is running at 90 km/h maximum in exact scale on my tracks. When the problem appeared, she, just, could not reach that speed on the tracks and I had to turn the speed knob to the end (at maximum) and, I must add, that I do not want to speak about motor overheating and such...Sad
So, if those peaks are just like they are, then, nothing can change the current situation and only time will have last word regarding how long new rotor will last (and brushes)...and that, may take years. If new rotor lasts for 10 years or so or something more, then, I shall leave them inside the locomotives, but I want to be ready on every possible situation and therefore, I shall try to get two or three 5* motors and replace the old ones in critical models (high speeds ones and frequently used ones) just in case. As I do not have, almost, any spare brushes more for my LFCM/SFCM locomotives, and I do have for 5* DCM motors, it is recommended for me...
Well, we shall see what will happen. Just to add that I do not have any room for more experiments any more just because I must choose to have the model as it is or to "play" around and push the limits of it and see how long will rotor or brushes stand such treatment...
If You have any suggestions or possible solutions, they are more then welcome!
Thank You Ray for the explanations!
Best wishes,
Zarko
GSRR Online
#47 Posted : 17 August 2010 13:29:53
Zarko,
Well you are certainly being very thorough. Most intriguing. I await the answer.
Thomas
#48 Posted : 18 August 2010 12:51:16
Hello, Thomas!
Thank You very much! All changings will be reported instantly on this forum and all answers no matter are they positive or negative!
To see how new rotors behave, it will take some time, but, the answers will be given!
Thank You on your support and comments!
Zarko
Tag as favorite
m-users theme by Webmaster, beta 1
Powered by YAF | YAF © 2003-2009, Yet Another Forum.NET
This page was generated in 0.645 seconds.
