Hello to all!
Not so long ago, I have stayed without two of my models due to the completely destroyed LFCM and SFCM rotors on my Marklin models E41 and E94(194) German "Crocodile"...
Until this happened, I thought that it is impossible to loose the model because of rotor malfunction, but, I was wrong...
Before I say anything in front, I want you to know that I am using Marklin control unit 6021 and my models with LFCM and SFCM motors are all equiped with Marklin c80 decoders.
I always use my models as the protoypical ones and their maximum speeds depends on the speed of the prototype. When I had analog system, I had no problems with any of my Marklin models, but, after I converted them to digital system, rotors on two of my models are destroyed completely. Such severe damages on the rotor's collector, I have not seen in my entire life on any other rotor of any kind!
Copper sectors of the collector are completely destroyed and there are a big holes at the end of copper sectors in a shape of elipse. Copper is deformed and vanished on the places where the collector sectors are isolated. Deformation of the copper sectors are incredible and never seen before!
There is no repair for such damigies at all, unfortunately...
All my models was fully operational until the conversion and after 11 years (only!) of usage, catastrophic malfunction ocured.
The symptoms are:
- Model can not reach its prototypical speed in exact scale 1:87
- Model significally slows down
- Motor overheating
- Abnormal consumption of brushes
and final stage
- Model can not start running by itself but only if you push it by a hand. After a few circles, model comes to a dead stop.
When you open the motor, you could see catastrophic damages of the rotor's collector. That is the point of no return.
All my Marklin models are professionally maintained and such damages just can not be seen during usual maintainings. Brushes was changed correctly, motor(s) was thoroghly cleaned, lubricating was properly done.
Nothing shows that such thing can happen. But, it is obvious that the digital impuls voltage which can be measured in kiloherz or kHz, is not the same as the 50-60 Hz in analogue mode.
Therefore, there is quiet reasonable doubt that LFCM and SFCM motors (rotors) can not stand such freqency for longer period of time! There is also doubt that Marklin as manufacturer, knew about this very well but did not suggest anything to their, faithful customers and just let it happen and they, forced the customers to buy their new 5* sets and decoders which are, at least, abnormaly expensive! I can add that the price Marklin asks for conversion sets is simply out of mind as there are other manufacturers on the market who are offered decoders under much lower prices and most of all, acceptable prices.
Some of us do not see this as a problem and that is quiet undrestandable, but some of us might have serious problems with their models and effort to keep them alive.
This all depends on the free will and how each of us is using his/hers models. If you spend couple of minutes with your models per month or per several months, then every model that you buy, no matter who made it, will last forever! If you have a layout and spend couple of hours per week with it or in two weeks per month, then you should have this on your mind all the time! Models that you are running will not run for longer period of time or at least, they will not last as you expected for sure and then, you will be forced to change the rotor (if you are lucky enuogh to find that spare part at all), or to buy one of the awfully expensive Marklin coversion sets for that purpose.
Certainly, no rotor(s) on this Planet are made to last forever!
The choice is all up to you!
Here, I want to use this opportunity to ask anybody here on this forum, if they have unwanted LFCM and/or SFCM rotors that are not needed anymore and if they are in acceptable good condition, please, contact me directly on my e-mail:
Webmaster: Email removed, use the email buttonI must add here that, almost, half of my collection is now in question because of the same failiure.
If someone can help me, please, contact me directly!
Thank you all on your attention and time!
With best regards,
Zarko Kristic
Computer Graphic Designer
Webmaster: Email removed, use the email buttonP.S. I am sorry, but I was unable to attach the picture of the damaged rotor to this message!
Edit by Webmaster - here's one picture of the actual damaged rotor.
