Hi.
I'm looking at upgrading and old 3031 to digital and I don't like the prices that M has for 60923 etc n(EUR - AUD is shocking and so is postage..... )
Does anyone have a listing of the parts?
I'll get my local distributor to order the parts in and whack a Lokpilot in.
Tom.
Joined: 17/09/2006(UTC) Posts: 12,203 Location: New Zealand
Tom, this is about the 32nd time I've posted this list, but there always seems to be a demand for it!!
Depending on whether your loco has a DCM, SFCM or LFCM motor, you should select the appropriate parts list. To that list add you Lokpilot or Loksound or whatever decoder you want!
Partnumbers for DCM motor (60901/60921)
386820 anchor 389000 field magnet 386940 motor shield 516520 inductor 601460 pair of brushes 276770 lamp Socket
Partnumbers in SFCM motor (60903/60923)
210888 anchor - 8 teeth 224615 field magnet 224613 motor shield 516520 inductor 601460 pair of brushes 276770 lamp Socket
Partnumbers in LFCM motor (60904/60924)
214118 anchor - 7 teeth 210888 anchor - 8 teeth 210882 field magnet 214121 motor shield 516520 inductor 601460 pair of brushes 276770 lamp Socket
You may also want:
231470 Soldering lugs for grounding the motor 600760 Capacitors 516520 Chokes 601460 Brushes 610080 Lamp bi pin 0.7 VA @ 22 V Digital
ESU HAMO magnets for use with existing AC motors
ESU 51960 Permanent magnet like Marklin 220560, (LFCM) ESU 51961 Permanent magnet like Marklin 220450, (SFCM) ESU 51962 Permanent magnet like Marklin 235690, (DCM)
OK Tom, the 3031 uses a SFCM motor, so use the SFCM parts list. Cheers.
Hi David, Thanks for the 32nd time   Would it be an idea to have your list added to the "Digital Corner" as a reference for digital conversions? Kind regards Guus |
Kind regards, Guus |
Joined: 23/03/2005(UTC) Posts: 2,497 Location: Denmark
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Bigdaddynz <br />Partnumbers in LFCM motor (60904/60924)
214118 anchor - 7 teeth 210888 anchor - 8 teeth 210882 field magnet 214121 motor shield 516520 inductor 601460 pair of brushes 276770 lamp Socket Thanks again for the list, Bigdaddy. I believe there is an additional motor shield in the kit numbers listed for LCFM: 210881 motor shield |
Regards, Benny - Outsider and MFDWPL  |
Guus,    Good idea, I shall email our esteemed webmaster..... Benny, I think you may be right. I was reading about it in one of the recent Marklin Magazines. I will add it to my list. Thanks. To clarify the list, you need 2 516520 inductors for every motor conversion you perform.
Hi Bigdaddy.
You might consider to add the following to the paragraph:
You may also want:
ESU51950 Female cable kit for NEM 652 plugs (Beware! DCC colour scheme).
Useful when converting el- and diesel locos with ample space for plug-in decoders with NEM 652 8-pin plugs (Lokpilot 3.0 and Kühn T145P amongst others).
Unfortunately I don't know a number for the newer 21-pin interface.
Thanks Benny, have added the item, as you suggest. I have also emailed our esteemed webmaster with Guus' suggestion.
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Benny: <br />...............................................
You may also want:
ESU 21 pin adapter:51967 21MTC-Adapterplatine. or, HAG 501025-75 Schnittstelle 21pol. ,which is equivalent,however it's already completely wired. Kind regards Guus |
Joined: 21/10/2004(UTC) Posts: 25,047 Location: United Kingdom
Very good, Thanks for the list, Juhan.  |
Large Marklinist layout with C-tracks/Central station 2/Mobile station 2/Boosters 60174s/Marklin collector since 1990s/Collector Marklin from the 1950s/Favorites Steam class BR01/BR03/BR05/BR50/Insider Club membership. |
Added the items from Guus into the list... |
Juhan - "Webmaster", at your service... He who asks a question is a fool for five minutes. He who does not ask a question remains a fool forever. [Old Chinese Proverb] |
Thank you all and thank you webmaster! - all the parts lists have been saved and my 3031 can live again!
Tom.
